How Far Does a Rocket Travel in 10 Seconds at 3600mph?
  • Thread starter Bill Raines
  • Tags
    Acceleration
In summary, the problem statement involves a rocket that blasts off and reaches 3600mph after 10 seconds, traveling straight up. The relevant equation used to find the average acceleration is 5280 feet/second^2. However, the problem mentioned in the conversation also includes a skydiver traveling horizontally before pulling the cord, but it lacks complete information and relevant equations.
Bill Raines
Member advised to fill out the template, especially the attempt at solution, for all homework help requests.
A rocket blast off. In 10.0 seconds it is at 10,000 ft, traveling at 3600mph, The rocket is going straight up
four possible answer
5280 ft/s^2
528 ft/s^2
100 ft/s^2
200 ft/s^2
The homework format you ignored is not as much a suggestion as it is a forum requirement.
What equations do you think are relevant?
Where is your attempt?
Also, you should state the entire question and all relevant information exactly as it was given.
It looks like the rocket doesn't reach 3600mph until 10 seconds into the burn. In this case
3600 mile/hour x 5280 feet/mile x 1 hour/3600 seconds = 5280 feet/second
5280 feet/second
______________ = 528 ft/second^2
10 seconds
5280 feet/second
10 seconds
On the assumption that you are asked to find the average acceleration, that looks right.
@Bill Raines ,
You are still ignoring this portion of @RedDelicious ' reply to you.
Include the entire problem statement in the text of your post, even if you have stated part of the problem statement in the title.
There is no acceleration. How far does the skydiver travel horizontally before pulling the cord?
What skydiver? Where is a skydiver mentioned in your original problem statement?
This thread is going nowhere fast, what with the lack of complete problem statement, relevant equations, and attempt at solution. I am locking this thread. If you wish to pursue the question please re-post it in a new thread, being sure to state the complete problem statement as given to you, any equations from your notes or text that you think might be relevant, and show what you've tried in the way of an attempt at solution.
FAQ: How Far Does a Rocket Travel in 10 Seconds at 3600mph?
What is the acceleration?
Acceleration is the rate at which an object's velocity changes over time. It is a vector quantity, meaning it has both magnitude and direction.
How is acceleration calculated?
Acceleration can be calculated by dividing the change in velocity by the change in time. The formula for acceleration is a = (vf - vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
What are the units for acceleration?
The units for acceleration depend on the units used for velocity and time. In the SI system, the standard unit for acceleration is meters per second squared (m/s²).
What is the difference between acceleration and velocity?
Velocity is the rate of change of an object's displacement, while acceleration is the rate of change of an object's velocity. In simpler terms, velocity tells us how fast an object is moving, while acceleration tells us how much an object's speed is changing.
What are some real-life examples of acceleration?
Acceleration can be observed in many everyday experiences, such as a car speeding up or slowing down, a roller coaster going up or down a hill, or a person jumping and then landing on the ground. It can also be seen in the movement of objects due to gravity, such as an apple falling from a tree.
