MHB How far does the tip of the hour hand move in 3 hours?
  • Thread starter Thread starter dtippitt
    Clock hand
To determine how far the tip of the hour hand moves in 3 hours, the arc length formula is applied. The hour hand, 2 cm long, moves through a quarter of a circle in that time, equivalent to 90 degrees or π/2 radians. The circumference of a circle is calculated as 2πr, leading to a quarter circumference of (1/4) * 2π * 2 cm. This results in a movement of π cm, which is approximately 3.14 cm. Thus, the tip of the hour hand moves about 3.14 cm in 3 hours.
dtippitt
How far to the nearest hundreth cm, does the tip of the hour hand on a clock move in exactly 3 hours if the hour had is 2.00 cm long?
I think you are supposed to use arc length formula.
This is what I got so far:
s=r(radian symbol) = 3=1(radian symbol)
Mathematics news on Phys.org
Re: Possible trignomery and distance formula
the hour hand of an analog clock moves 1/12 of a revolution in one hour.
one revolution is 2pi radians
$s = r \cdot \theta$
take it from here?
In 3 hours, the hour hand turns through a right angle, i.e. a quarter of a circle. What is a quarter of the circumference of a circle of radius 2 cm?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
