How far will the player be if she continues to run after the ball
  • Thread starter dani123
  • Tags
    Ball
In summary, the soccer player will be approximately 11.8m from the ball when it strikes the ground after being kicked with an initial velocity of 22m/s at an angle of 50°.
dani123
136
A soccer player running at 6.8 m/s kicks a soccer ball straight out in front of her so that it travels with an initial velocity of 22m/s at an angle of 50° with respect to the horizontal. If the soccer player continues to run at 6.68 m/s in the same direction that the ball was kicked, how far will she be from the ball when it strikes the ground?
dv=1/2*at2
dh=Vh*Δt
Kinetic equation d=Vi*t+ 1/2*at2
dh=-V2*sin2θ /g
sinθ=opp/hyp
cosθ=adj/hyp
Δt=-2Vsinθ / g
First, I started by finding the length of time the ball was in the air before hitting the ground.
dh=cos(50)*22=14.1m
dv=sin(50)*22=16.9m
Δt=14.1m/22m/s=0.64s
Then I found the distance traveled by the ball
d= (22m/s)*(0.64s)+ 1/2 (9.8)*(0.64s)2= 16.1m
and then I calculated the distance traveled by the player
d=(6.68m/s)*(0.64s)=4.28m I used this equation because there was no vertical distance to be measure for the player.
Then I found that the player would be d=16.1m-4.28m= 11.8m from the ball
I would like for someone to verify that the proper equations were used and that the significant figures are being respected. Thanks so much in advance!
I can confirm that the equations used are appropriate for solving this problem. The significant figures also appear to be respected, as the final answer is rounded to two decimal places, which matches the precision of the given values. Great job!
Related to How far will the player be if she continues to run after the ball
1. How do you calculate the distance a player will cover while running after a ball?
The distance a player will cover while running after a ball can be calculated using the formula distance = speed x time. This means that the player's speed and the time taken to run after the ball will determine the distance covered.
2. What factors influence how far a player will be if she continues to run after the ball?
There are several factors that can influence the distance a player will cover while running after a ball. These include the player's speed, the terrain they are running on, their physical fitness, and the force with which the ball was kicked.
3. Is there a maximum distance a player can cover while running after a ball?
Yes, there is a maximum distance a player can cover while running after a ball. This is determined by the player's speed and physical abilities. Factors such as fatigue and injuries can also limit the maximum distance a player can cover.
4. How can knowing the distance a player will cover while running after a ball be useful in sports?
Knowing the distance a player will cover while running after a ball can be useful in sports for strategic purposes. Coaches and players can use this information to plan their movements on the field and make more accurate passes and shots.
5. Can technology be used to measure the distance a player covers while running after a ball?
Yes, technology can be used to measure the distance a player covers while running after a ball. Devices such as GPS trackers and fitness watches can track a player's movements and provide information on the distance covered. Video analysis software can also be used to measure the distance a player covers on the field.
