How far will this bullet drop in 3 seconds
In summary, a bullet is fired horizontally from a 100-meter tall building with a speed of 850 meters per second. In 3.00 seconds, the bullet would have dropped by 29.4 meters. As for the ball being kicked at an angle of 30 degrees with an initial velocity of 5.0 meters per second, its vertical velocity increases as it rises. However, the correct answer is that the vertical component of its velocity decreases. To find the displacement of the bullet, its y displacement should be calculated instead of its x displacement.
MIA6
233
1. A bullet is fired horizontally from the roof of a building 100. meteres tall with a speed of 850 meters per second. Neglecting air resistance, how far will the bullet drop in 3.00 seconds?
1) 29.4 m 2) 44.1 m 3) 100. m 4) 2,550
Since the horizontal speed should be constant throughout, so I think 850 is the horizontal initial speed, so I did: 850*3=2550 m, but it's the wrong answer.
2. A ball is being kicked by a foot and rising at an angle of 30 from the horizontal. The ball has an initial velocity of 5.0 meters per second. As the ball rises, the vertical component of its velocity 1) decreases 2) increases 3) remains the same
I think it increases because the vertical component is 5*sin30=2.5, and once the angle increases, then it's 5*sin 45=3.54. So it obviously increased, but the answer is 1) decreases, so I don't know.
Thanks a lot for help.
hint for number one
it's asking how far the bullet dropped, so find its y displacement, not x...
hint for number two
if the ball's velocity continued to increase it wouldn't come back down...also your velocity should look like V = Vosin@ - 1/2gt^2
hope this helps
I would approach these questions by applying the principles of physics and using relevant equations to solve for the answers. Let's break down each question and its solution:
1. How far will the bullet drop in 3 seconds?
To answer this question, we need to consider the motion of the bullet in both the horizontal and vertical directions. We can use the equation d = v0t + 1/2at^2, where d is the distance, v0 is the initial velocity, t is the time, and a is the acceleration. Since the bullet is fired horizontally, the initial vertical velocity is 0 and the acceleration due to gravity is -9.8 m/s^2. Plugging in the given values, we get:
d = 0 + 1/2(-9.8)(3)^2
d = 44.1 m
Therefore, the bullet will drop 44.1 meters in 3 seconds.
2. As the ball rises, the vertical component of its velocity decreases.
To solve this question, we can use the equation v = v0 + at, where v is the final velocity, v0 is the initial velocity, a is the acceleration, and t is the time. Since the ball is rising, the acceleration due to gravity is acting against its motion, so it will decrease the vertical component of its velocity. We can calculate the final velocity at any given time by using the equation v = v0 + at. In this case, we are interested in the final vertical velocity when the ball reaches its maximum height, so t = 0. The equation becomes:
v = 5*sin30 + (-9.8)(0)
v = 2.5 m/s
Then, we can use the same equation at the peak of the ball's trajectory, when it starts to fall back down. At this point, the time is t = 2.5/9.8 = 0.255 seconds. The equation becomes:
v = 2.5 + (-9.8)(0.255)
v = 0 m/s
As we can see, the vertical component of the velocity has decreased from 2.5 m/s to 0 m/s. Therefore, the correct answer is 1) decreases.
In conclusion, as a scientist, I would use the principles of physics and relevant equations to solve these types of questions. It is important to carefully consider all the
Related to How far will this bullet drop in 3 seconds
1. How does the initial velocity of the bullet affect its drop distance in 3 seconds?
The initial velocity of the bullet plays a significant role in determining how far it will drop in 3 seconds. The faster the initial velocity, the farther the bullet will travel horizontally before it reaches the ground. This means that the drop distance will be greater for a bullet with a higher initial velocity compared to one with a lower initial velocity.
2. Does the angle at which the bullet is fired affect its drop distance in 3 seconds?
Yes, the angle of the bullet's trajectory does affect its drop distance in 3 seconds. The steeper the angle at which the bullet is fired, the shorter the drop distance will be. This is because a steeper angle results in a shorter horizontal distance traveled, meaning the bullet will reach the ground sooner in 3 seconds compared to a shallower angle.
3. How does air resistance impact the drop distance of a bullet in 3 seconds?
Air resistance, also known as drag, will slow down the bullet as it travels through the air. This means that the bullet will not drop as far in 3 seconds as it would without air resistance. The amount of air resistance depends on factors such as the bullet's shape, speed, and air density.
4. Can the bullet's mass affect its drop distance after 3 seconds?
The mass of the bullet does not directly affect its drop distance after 3 seconds. However, a heavier bullet may have a higher initial velocity, resulting in a longer drop distance. Additionally, the weight of the bullet can impact its aerodynamics and therefore its air resistance, which can indirectly affect its drop distance.
5. How accurate is the calculation of a bullet's drop distance in 3 seconds?
The calculation of a bullet's drop distance in 3 seconds is based on the laws of physics and can be quite accurate if all factors are taken into account. However, there are certain variables, such as wind or changes in air density, that can affect the bullet's trajectory and ultimately the drop distance. Therefore, the calculated drop distance may not always be 100% accurate in real-world scenarios.
