tackyattack
- 56
If you released a balloon filled with helium, how high would it go if it never burst from the pressure change?
Antiphon said:Balloons have gone more than 3 times that height.
In the 50's a man was hoisted 85,000 feet and then jumped out and parachuted back to earth.
Nabeshin said:I figure the balloon would stop rising roughly when the ambient mass density is the same as the density inside the balloon. If the balloon were filled with Helium, mass density of ~0.1g/L. Judging from this graph: http://upload.wikimedia.org/wikipedia/commons/d/de/Atmosphere_model.png , that corresponds to a height ~7-8 km.
pergradus said:The ultimate deciding factor is the elasticity of the balloon...
As the balloon rises it will expand with decreasing air pressure and become less and less dense. This expansion can't continue forever though, so eventually the balloon can't become any less dense and still stop rising.
However, I'm really not sure what would happen if the balloon could expand forever... I assume it has to stop somewhere, but there's always going to be internal pressure which means the balloon will expand to an infinite radius... Interesting to think about.
tackyattack said:Here is why I am asking this:
A couple days ago I thought this to my self, what if I put a string on the outside of the balloon on the radius of the balloon attached to a switch so that when the balloon expands bigger it triggers the button. At the "nozzle" of the balloon I would have a solenoid valve that leads to a big, light, plastic bag. So when the balloon expands the button gets pressed which then opens the solenoid, releasing the gas into the bag. Then when the balloon gets back to its original size it closes the solenoid valve so the gas stops flowing into the bag.
So technically the balloon would never burst and the extra bag keeps the helium so there is still lift. So, how high could the helium balloon go and still have lift?
That graph is difficult to read, since they made the gridline spacings all wrong. Note the factor of 1000 per major gridline, yet the minor gridlines are as if it's 10x between major gridlines.Nabeshin said:I figure the balloon would stop rising roughly when the ambient mass density is the same as the density inside the balloon. If the balloon were filled with Helium, mass density of ~0.1g/L. Judging from this graph: http://upload.wikimedia.org/wikipedia/commons/d/de/Atmosphere_model.png , that corresponds to a height ~7-8 km.
rcgldr said:If the balloon had no limit on expansion, it should rise until it nears the exoshpere, which is a mixture of helium and hydrogen, with less density than an object containing pure helium at the same pressure. This is 350km -> 800km above the Earth's surface, and higher than low orbit vehicles, such as the space station, which orbits in the thermosphere (it's ranges from 80km to about 350km, space station orbits at 320 km to 380km).
True, I was assuming an ideal massless balloon, since it's already unrealistic to assume the huge rate of expansion required to hold the helium at extreme altitudes. The other issue is no one would want stationary space debris at the same altitudes as low Earth orbit satellites and space stations. All the stuff launched up in low orbits is done with the plan that eventuallly the small amount of atmoshpere up there will slow them down and cause them to re-enter the denser part of the atmosphere and burn up. In the case of the space station, or the Hubble telescope, they rely on occasional oribital boost from shuttles. I think there are no more planned for the Hubble, so it's destined to get burnt up.pallidin said:Don't forget the weight of the balloon itself, regardless of expansion capabilities.
The size of the balloon plays a crucial role in how high it can rise. A larger balloon will displace more air, causing it to rise higher. Therefore, a larger helium balloon will reach a higher altitude before it bursts.
The weight limit for a helium balloon to reach a certain height depends on the size of the balloon and the amount of helium it contains. Generally, a larger balloon with more helium will be able to lift more weight and reach a higher altitude before bursting.
The burst height of a helium balloon is determined by several factors, including the size of the balloon, the amount of helium it contains, and the atmospheric conditions. A larger balloon with more helium will rise higher, but it will also burst at a lower altitude due to the increasing air pressure.
No, a helium balloon cannot continue to rise indefinitely. Eventually, it will reach an altitude where the air pressure is too low for it to rise any further. Additionally, as the balloon rises, the helium gas will expand, causing it to eventually burst.
Air temperature has a significant impact on the maximum height of a helium balloon. Warmer air is less dense than colder air, allowing the balloon to rise higher before bursting. On the other hand, colder air is more dense and will cause the balloon to burst at a lower altitude.
