How fast do fundamental forces propagate?
In summary: The Casimir effect can be derived using virtual particles, but they are not necessary.The calculations for the Hawking radiation do not have virtual particles at all. The description with particle/antiparticle pairs sounds nice, but it is wrong.
GhostLoveScore
149
So, I've been looking at this chart
Only Electro-magnetic force is carried by massless particle - photon. And it propagates at the speed of light. Now take Weak and Strong force. They are carried by bosons and gluons. They have mass. So, what is the speed of propagation of Weak and Strong forces, if that question makes any sense. It seems that it can't propagate at the speed of light because you can't have mass traveling at the speed of light.
Gluons are massless as well.
As far as it makes sense, the speed is still the speed of light, but especially for the weak interaction that concept is not really meaningful. You don't need a particle going from A to B to have an interaction - you need the fields at B change as a result of whatever happens at A. The fields are not particles.
Likes GhostLoveScore
I have trouble understanding why we have force carrier particles. As you said, and I understood that, for electric force to act on something there has to be electric field. But I don't understand why do we have particles that carry weak and strong forces. Can't we also have some kind of field for each of those two forces, like we have electric and magnetic field for electric and magnetic forces?
Sometimes the exchange of particles is a good model. Sometimes it is not. Depends on the process.
Alright, what about electric force. If we have positive charge located at distance "d". There is an electric field going from positive charge. For an electron in that field there is a force F=E*q.
Now if we look at force carriers of the electric force - photons. How does electric force acts? Does positive charge produces photons and electron absorbs them? Can we see those photons?
It is possible to model the interaction via the exchange of virtual photons, but they are just mathematical tools to approximate the field, because working with the field can be too challenging sometimes.
No, there are no real photons involved.
mfb said:
It is possible to model the interaction via the exchange of virtual photons, but they are just mathematical tools to approximate the field, because working with the field can be too challenging sometimes.No, there are no real photons involved.
Disclaimer: I almost don't know anything about this.
I am very confused, because I always thought there was some physical reality to virtual particles.
That they are only a "mathematical tool" is completely new to me.
I heard that there were some interactions that could only really be explained through them.
For example Hawking radiation or the casimir effect.(both of which haven't been measured to my knowlege, but that's besides the point)
Am i somehow confusing virtual force carriers or gluons with other virtual particles ?:confused:
Physics is not about reality, but how real is something you cannot detect in any way, something that is present in approximations only and does not appear at all in more precise calculations?
Nothing needs the concept of virtual particles.
Edit: weirdoguy was faster with the links.
Thanks for clearing up that confusion, although i got to say it is a little shocking to me. :nb)
For example Hawking radiation ...
Hawking said early on that the "virtual particle pair" explanation of Hawking Radiation is an ANALOGY, not an actual description of what happens. It was the only way he could think of to explain in English something that really can only be explained in the math.
Related to How fast do fundamental forces propagate?
1. How do fundamental forces propagate?
Fundamental forces propagate through the exchange of carrier particles, such as photons for electromagnetism and gluons for the strong nuclear force.
2. Does the speed of light limit the propagation of fundamental forces?
Yes, the speed of light is the maximum speed at which fundamental forces can propagate. This is due to the fact that all of the carrier particles have zero rest mass and therefore must travel at the speed of light.
3. Are all fundamental forces propagated at the same speed?
No, each fundamental force has its own unique speed of propagation. The speed of light is the maximum speed, but the actual speed for each force may be less than this depending on the specific force and its carrier particles.
4. How fast do fundamental forces propagate in a vacuum?
In a vacuum, fundamental forces propagate at the speed of light. This is because there are no particles or other medium to slow down or interact with the carrier particles.
5. Can the speed of fundamental forces be altered or manipulated?
Yes, the speed of fundamental forces can be altered or manipulated under certain conditions. For example, the speed of light can be slowed down in a medium such as water or glass. Additionally, in certain theories like string theory, it is believed that the speed of light may not be constant and could potentially be altered by certain conditions.
  • Other Physics Topics
  • Beyond the Standard Models
