- #36
- 10,349
- 1,525
Andrew Mason said:I don't think it is just a matter of accelerating the charge. It has to be an acceleration that results from an electromagnetic interaction with the charge.
A good example is the EM interaction between an electron and a bending or jiggling magnet in a synchrotron. The electro-magnetic force on the moving electron that is provided by the bending or jiggling magnets in the rest frame of the laboratory would appear to the electron (ie in the moving electron's frame of reference) as a moving field with electric and magnetic components. It would interact with the electric component only. (This has to be the case because in the electron's 'stationary' reference frame, the electron has no magnetic field for the magnet to interact with).
When looking at the interaction between a charge and an external field, you always have the option to use whatever inertial frame of reference you want.
You can either use the intantaneous frame of the charge, or the laboratory frame, whichever is simpler.
In either case you will find that accelerating the charge generates electromagnetic radiation. In many circumstances the motion of the charge is known, but calculating the fields on it is not. The problem of "back reaction" of an accelerating point charges, for instance, is a well known source of infinities in classical EM theory. With quantum theory this issue goes away, as do many of the "point charge" issues, but it's better to avoid the complexities of quantum theory when the problem is basically classical, and this means that it's generally better to analyze the problem in terms of the motion of the charge.
