MHB How fast is the area of triangle formed
  • Thread starter Thread starter karush
    Area Triangle
karush
MHB
9 A Ladder 13ft long is leaning against the side of a building.
If the foot of the ladder is pulled away from the building at a constant rate of 8in per second how fast is the area of triangle formed by the ladder, the building and the ground changing (in feet squared per second) at the instant when the top of the ladder is 12 feet above the ground
https://www.physicsforums.com/attachments/1520
$$A=\frac{1}{2}BH=\frac{1}{2}xy$$
$$\frac{d}{dt}A=\frac{d}{dt} \left(\frac{1}{2} xy \right)
\Rightarrow \frac{dA}{dt}=\frac{1}{2}x\frac{dy}{dt}+\frac{1}{2}y\frac{dx}{dt}$$
since $$\frac{dy}{dt}\text{ at y }= 12\text { is }\frac{-5 ft}{12 ft}\cdot \frac {2ft}{3 sec} = -\frac {5 ft}{18 sec}$$
then substituting
$$\frac{dA}{dt} = \frac{119}{36}\frac{ft^2}{sec}$$
hopefully
Looks good to me!
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
