How fast must a satellite leave Earth's surface
In summary, the satellite needs to leave Earth's surface with a velocity of approximately 7404.5 m/s to reach an orbit with an altitude of 895 km. This takes into account the necessary velocity to escape the Earth's gravitational field and the additional velocity needed to reach the desired altitude. Conservation of energy can be used to calculate the final velocity.
fizzyy
How fast must a satellite leave Earth's surface to reach an orbit with an altitude of 895 km?
v = √GM/r
G = 6.67 x 10^-11
M = 5.98 x 10^24
r = (6.38 x 10^6) + (8.95 x 10^5) = 7.275 x 10^6
v = √(6.67 x 10^-11)(5.98 x 10^24)/(7.275 x 10^6)
v = 7404.5 m/s
But this is the speed the satellite needs to stay in orbit. Is this the same speed that it needs to leave the Earth's surface? Do I need to use v = √2GM/r instead to find the velocity it needs to escape the gravitational field at Earth's surface and go into orbit?
To the velocity required to orbit at that height, you need to add the velocity necessary so that the kinetic energy can be 'traded off' for the change in potential energy to get to that height.
Would that be
Ek = ΔEg
1/2mv^2 = -GMm/r2 - (-GMm/r1)
solve for v, then add it to 7404.5 m/s?
Ohhh wait, conservation of energy applies, right?
Ek1 + Eg1 = Ek2 + Eg2
just plug v2 = 7404.5 m/s in
FAQ: How fast must a satellite leave Earth's surface
How fast must a satellite leave Earth's surface?
The speed at which a satellite must leave Earth's surface depends on a variety of factors, including the orbit it is trying to achieve, the mass of the satellite, and the gravitational pull of Earth. However, on average, a satellite must reach a speed of about 17,500 miles per hour to successfully enter orbit.
What determines the speed needed for a satellite to leave Earth's surface?
The speed needed for a satellite to leave Earth's surface is determined by its escape velocity, which is the minimum speed needed to break free from Earth's gravitational pull. This velocity is dependent on the mass and radius of the Earth, and is approximately 25,000 miles per hour.
Can a satellite leave Earth's surface at any speed?
No, a satellite cannot leave Earth's surface at any speed. If it is not traveling fast enough, it will not be able to overcome the pull of Earth's gravity and will fall back to the surface. If it is traveling too fast, it may escape Earth's gravity and enter into a solar orbit.
How does the shape of Earth affect the speed needed for a satellite to leave its surface?
The shape of Earth does not significantly affect the speed needed for a satellite to leave its surface. As long as the satellite reaches the necessary escape velocity, it will be able to leave Earth's surface regardless of its shape. However, the shape of Earth can affect the specific orbit the satellite is able to achieve.
Can a satellite leave Earth's surface without any initial speed?
No, a satellite cannot leave Earth's surface without any initial speed. It must have an initial velocity in order to overcome Earth's gravitational pull and enter into orbit. This initial velocity can be achieved through various methods, such as rocket propulsion or gravitational slingshot maneuvers.
