How fast must the spacecraft travel? Special Relativity
In summary, the spacecraft must travel at a speed greater than 0.48 the speed of light to make the trip to α Centauri in 16 years.
VaccumEnergy
[/B]
1. Homework Statement
A spacecraft is prepared to visit α-Centauri, which is at the distance 4.37 light years from the Sun. Provisions for the crew are prepared for the duration of 16 years. How fast must the spacecraft travel for this provision to be enough?
Answer this question in two ways by considering:
(i) time dilation
(ii) length contraction. (The period of acceleration, dece- laration, turnaround and visit are neglected compared to the whole time of the travel)
Time dilation:
t = gamma*t0, where t is the time from the Earths inertial frame and t0 is the 'proper time' i.e. time perceived from Earth on the rocket.
Length Contraction:
l=l0/gamma, where l is the length perceived from an inertial frame of a body moving with speed v relative to it of length l, l0 is length perceived when v = 0
gamma = 1/(1-v^2/c^2)^-1/2, v is relative velocity and c is speed of light.
[/B]
I'm unsure how to begin this question, been stuck for almost an hour. Making me feel stupid, please helppppp
Let's work on the "time dilation" approach.
You have an equation ##t = {gamma}*t_0##
You know from the problem statement that t (the time elapsed according to the spacecraft clocks must be no more than 16 years.
Can you calculate ##t_0## (the time taken for the trip according to Earth clocks) in terms of the distance and the spacecraft velocity?
Can you expand ##t = {gamma}*t_0## in terms of the spacecraft velocity and the distance from Earth to Alpha Centauri?
The proper time, on the spacecraft , is given by:
##t_0 = t / {gamma}##
The proper time must be less than ##16[years]##, is a constraint (i.e. ##t/{gamma} < 16 {years} ##)
It then follows that :
##t/{gamma} = (2*4.37*c*years)/(v*{gamma}) < 16 years##
Now solving for ##v/c## gives :
##v/c >0.48 (approx) ##Does that look okay?
It is always wise to do a sanity check on results like this. Scribbling on the back of an envelope...
Your computed result is a v/c of 0.48. That means that the trip will take 4.38 light years / 0.48 = 9.125 Earth years one way. 18.25 years round trip. This is dilated by a gamma of 1.14 and the result is 16 years of elapsed shipboard time, as desired.
Yes, that looks right.
Related to How fast must the spacecraft travel? Special Relativity
1. How is the speed of light related to the speed of spacecraft?
The speed of light is a fundamental constant in the universe and is approximately 299,792,458 meters per second (m/s). According to Einstein's theory of special relativity, the speed of light is the maximum speed at which any form of matter or information can travel. This means that no spacecraft can exceed the speed of light, as it would violate the laws of physics.
2. Can a spacecraft travel at the speed of light?
No, a spacecraft cannot travel at the speed of light. As mentioned before, the speed of light is the maximum speed that anything can travel in the universe. As an object approaches the speed of light, its mass increases exponentially, making it impossible to reach the speed of light.
3. How fast must a spacecraft travel to experience time dilation?
According to special relativity, the closer an object travels to the speed of light, the slower time passes for that object. This is known as time dilation. To experience noticeable time dilation, a spacecraft would need to travel at extremely high speeds, close to the speed of light. For example, at 99% of the speed of light, time would pass 7 times slower for the spacecraft than for an observer on Earth.
4. What is the relationship between speed and mass in special relativity?
In special relativity, the mass of an object increases as its speed increases. This is due to the equation E=mc², where E represents energy, m represents mass, and c represents the speed of light. As an object's speed approaches the speed of light, its energy and therefore its mass also increases.
5. How does the speed of a spacecraft affect its length and shape?
According to special relativity, an object's length and shape are also affected by its speed. As an object approaches the speed of light, it appears to shrink in length and become compressed in the direction of motion. This is known as length contraction. Additionally, an object's shape can appear distorted when viewed from different perspectives due to special relativity's effects on space and time.
