How fast to go 1000 years into the future
In summary: And then there's the problem with the 'slingshot' effect; you can only fly close to a black hole without getting pulled apart by the enormous tidal force, which means you can't really use the gravity of the black hole to slingshot yourself to a different location. But maybe this idea sparks something in your head for a more feasible solution.In summary, traveling 1000 years into the future relative to an observer on Earth would require the traveler to travel at a speed close to the speed of light. There is a calculation that can determine the necessary speed, which takes into account the ratio of coordinate time to proper time. For a two-hour trip, the
rlinsurf
25
How fast (close to c in mph or m/s) would I need to go to go 1000 years into the future relative to an observer on Earth?
In general, is there a calculation which can tell me how fast I need to be going to go x distance in time relative to an observer on earth?
even at rest you will go 1000 years coordinate time in 1000 years of proper time.
The ratio of coordinate time to proper time is:
1/sqrt(1-v^2/c^2)
I think the equation you want it this:
[tex]t'=\frac{t-\frac{vx}{c^{2}}}{\sqrt{1-\frac{v^{2}}{c^{2}}}}[/tex]
where t = 1000 and you don't die during the journey. So, let's say you devote 50 years to the journey, how fast do you need to go to end up 1000 years after you left?
Let's say you do the journey in two legs of 25 years each (away from the Earth for 25 years ship time, and back for another 25 years), which means you can eliminate the second term (vx/c2).
Then you get Dalespam's equation.
[tex]t'=\frac{t}{\sqrt{1-\frac{v^{2}}{c^{2}}}}[/tex]
Rearranging:
[tex]v=c . \sqrt{1-\frac{t^{2}}{t'^{2}}}[/tex]
So plugging in your figures (or my figures, since I chose 50 years):
[tex]v=c . \sqrt{1-\frac{2500}{1000000}}[/tex]
v = 0.998749c = 2.996 x 108 m/s
If you want to go a bit slower, and can afford to wait 100 years you can travel a bit slower at 0.9c (2.7 x 108 m/s).
If we assume you take a relatively small spaceship, the space shuttle weighing 2000000 kg, and blithely ignore the fuel issue, the work done to accelerate you (using the first figure) is about 1.8 x 1023 kJ. This is not terribly far from the total annual energy consumption for the world at 2004 figures - times 500.
So ... I doubt you could persuade anyone to fund your mission :smile:
cheers,
neopolitan
(PS the accuracy of my figures might be a bit dicky, but the magnitudes should be right)
neopolitan-- That's great, thank you.
So then for a two hour trip that would be
[tex]v=c. \sqrt{1-\frac{4}{76737600000000}}[/tex][tex]v=c. \sqrt{0.9999999999999479}[/tex]v = 2.998 x 108 m/s
Is that right?
nm. I think I got it.
Thanks again. :)
v = 2.998 x 108 m/s
Is that right?
I was using c = 3*108 m/s but c = 299792458 m/s. I've since then put the equation into a spreadsheet so I can play with numbers more easily.
Using c=299792458 m/s:
Speed to travel 1000 years in 2 hours = 299792457.999992 m/s = 0.999999999999974c
Speed to travel 1000 years in 50 years = 299417482.921418 m/s = 0.998749218c
Speed to travel 1000 years in 100 year = 298289729.449314 m/s = 0.994987437c
So, yes, for two hours 2.998x108 m/s is right, but that's near enough to light speed to prevent your trip anyway. There is talk that neutrinos don't actually travel at the speed of light but slightly less than it, the speed is in the order of 0.999999c so to travel 1000 Earth years in 2 hours of ship time, you'd (probably) have to travel faster than neutrinos.
cheers,
neopolitan
To go a 1,000 years in the future you need to travel for 1,000 years - there's a direct relationship between time and distance. As you can't magically leap to speeds very close to lightspeed then you need to take time getting up to speed, then time getting back down. Just how quick you do that determines how long the journey will take for you subjectively.
Fly out 500 light-years and fly-back. At 1 gee the trip takes about 1003.8 years for everyone at home and 1.94*ln(2(1 + 500*1.0323/2))*2 = 24.25 years on-board. Perhaps a bit over-long for what you intended.
Perhaps you can accelerate at 1,000 gees - and remain alive via some kind of electromagnetic support system. The trip-time drops for you and those at home. On ship the travel-time is now (1.94/1000)*ln[2(1+500*1000*1.0323/2)]*2 = ~0.05 years or 18.64 days. Of course the question of just how you remain alive is up to your imagination. Suspended in some kind of oxygenated fluid might work - salamanders live happily in centrifuges pushed up to about that many gee. Maintaining such extreme acceleration for so long is beyond my imagining in engine terms. Perhaps you know how to make a warp-drive sphere.
Maybe a simpler way would be a kind of cosmic cable car system with black holes flying through space between different destinations. Just wait for one of the holes to pass by, fly your spaceship behind it and let the hole's gravity pull you along. Of course your exact trajectory would have to be calculated by computers, it won't just be a matter of getting behind the hole and then hopping off again later, it will have to be some kind of slingshot trajectory. Anyway, since gravity will affect you and the ship the same way (provided you don't get close enough to feel tidal effects), your body won't feel any acceleration at all.
Of course it might be a tad difficult to set up such a black hole transportation system. Getting those things to the right speed on the right trajectory so they follow a specific course around other, more massive black holes that serve as a kind of "poles" is not going to be trivial.
Actually, it might be safer to use neutron stars for the cable cars, and black holes only for the "poles". The neutron stars won't give quite as much pull, but they should be much easier to handle... ;-)
Would that work? :confused: One of the key features of Newtonian gravity is that it's approximately right -- it's not obvious to me that you could use a black hole as an inertial dampener.
OTOH, you could just use gravitational time dilation to solve the "go 1000 years into the future" problem, although I suppose that would be somewhat dangerous. (and not just because you risk crossing the event horizon accidentally)
For example, approach the hole in such a direction that you take a hyperbolic trajectory around the hole. So you fly towards it, get accelerated, turn around it, and fly away again in a different direction, like a comet from outer space that goes around our sun and flies away again. All of this is relative to the hole, which is moving at high speed, so if your exit trajectory is forward, you'll actually end up faster than the hole.
This kind of slingshot trajectories is used all the time to fly spacecraft through the solar system.
That would probably work too. The advantage is that you don't need to accelerate the holes, you can just use any old black hole and somehow put yourself on a trajectory that takes you around the hole just outside the event horizon and then out again.
Hi Guys
Two words: Tidal Forces.
Stellar mass black-holes have seriously nasty tidal forces. Even neutron stars do.
But a gravity compensator isn't so crazy. Charles Sheffield uses that trick in his McAndrews stories - a disk of high-density matter with a very high surface gravity is placed so the crew section is accelerated towards it while the disk itself is being accelerated away from the crew section. The crew module can ride up and down a central shaft to vary the felt gravity according to comfort. In the stories the disk accelerates at 100 gees and being so high-density it's a very good shield against radiation.
Of course to propel it to relativistic speeds requires a truly staggering power-source which means Sheffield employs a lot of handwavium in the form of zero-point energy. Oh well can't always be perfect... but the 1000 year voyage needed a lot of that handwavium anyway.
Yeah, stellar mass black holes do, but you can make the tidal forces at the event horizon arbitrarily small by making the black-hole arbitrarily large.
Related to How fast to go 1000 years into the future
1. How fast do we need to travel to go 1000 years into the future?
The speed required to travel 1000 years into the future depends on the concept of time dilation, which states that time passes slower for objects that are moving at high speeds. In theory, if we were able to travel at the speed of light (approximately 186,282 miles per second), time would pass slowly enough for us to reach the future in 1000 years. However, this is currently not achievable with our current technology.
2. Can we go 1000 years into the future by simply waiting?
No, it is not possible to go 1000 years into the future simply by waiting. Time travel into the future requires some form of movement at high speeds or being in close proximity to a massive object, such as a black hole. Without these conditions, time will continue to pass at a constant rate.
3. Is it possible to go 1000 years into the future and then come back to the present?
According to current scientific understanding, it is not possible to travel 1000 years into the future and then return to the present. The laws of physics suggest that traveling into the future is possible, but traveling back to the past is not possible.
4. How does Einstein's theory of relativity relate to traveling 1000 years into the future?
Einstein's theory of relativity is essential to understanding the concept of time travel into the future. The theory states that time is not absolute and can be affected by factors such as gravity and velocity. This means that as an object moves faster or experiences stronger gravitational forces, time will pass slower for that object compared to a stationary object.
5. Are there any potential consequences or risks associated with traveling 1000 years into the future?
While time travel into the future is a fascinating concept, there are currently no known risks or consequences associated with it. However, there are many ethical and philosophical implications that would need to be considered if time travel were to become a reality. Additionally, the potential for unintended consequences cannot be ruled out, as time travel is still a theoretical concept that requires further scientific advancements to be possible.
