How fast will the car now move?
  • Thread starter max1020
  • Tags
    Car
In summary, using Newton's Second Law and the equation v^2 = u^2 + 2as, it can be determined that the final velocity of the cart is 4.215 m/s after the machine applies a force of 1200N over a distance of 0.52m to a 100kg cart moving at 2.3m/s.
max1020
45
A 100kg cart is moving at 2.3m/s. A machine has been designed to apply a force of 1200N over a distance of 0.52m as this cart passes by. How fast will the car now move?
3. The Attempt at a Solution
I used a=fnet/m where fnet was 1200-0 so the answer I got was 2307.68 m/s^2. Is this right?
Why did you divide the force by the distance?
Is Newton's law "Force = distance times acceleration" or is it "Force = mass times acceleration"?Anyway, that gives you (if you do it correctly) the acceleration of the object, but the question didn't ask for the acceleration. You'll need to use the acceleration to find the final velocity.
Do you know about Work and Energy? (If not, that's fine, there are other ways to solve it.)
So a= 2.3m/s
max1020 said:
So a= 2.3m/s
Look at the units. Acceleration does not have units of m/s. Acceleration has units of m/s^2Do you know Newton's definition of force? (Also known as "Newton's Second Law")
It says:
Net Force = Mass times acceleration
Therefore (if you rearrange that definition)
Acceleration = Force divided by mass
=12 m/s^2
V=3.84
max1020 said:
1200/100
=12 m/s^2
Yes, that is correct.
max1020 said:
V=3.84
You need to explain yourself, otherwise I can't help you.
I used v^2= u^2+2as
=sqrt(2.3^2 + 2 x 12 x 0.52)
=3.84
Whoops is it 4.215
max1020 said:
Whoops is it 4.215
Yes, that is the correct answer.
Thank you!
FAQ: How fast will the car now move?
1. How is the speed of a car determined?
The speed of a car is determined by the distance it travels in a certain amount of time. It is calculated by dividing the distance traveled by the time taken to cover that distance.
2. What factors affect the speed of a car?
The speed of a car can be affected by several factors, including the engine power, weight of the car, aerodynamics, road conditions, and external forces such as wind resistance and friction.
3. Can a car's speed be increased or decreased?
Yes, a car's speed can be increased or decreased depending on the driver's actions. By pressing the accelerator, the car's speed can be increased, and by pressing the brake, the speed can be decreased.
4. How does the speed of a car change when going uphill or downhill?
When going uphill, the speed of a car decreases as it has to overcome the force of gravity. On the other hand, when going downhill, the speed of a car increases due to the pull of gravity. This change in speed is also affected by the slope of the hill and the car's weight and engine power.
5. Is the speed of a car constant?
No, the speed of a car is not constant. It can change depending on various factors such as road conditions, traffic, and the driver's actions. However, in ideal conditions, a car can maintain a constant speed if there are no external forces acting on it.
