I How Feynman proves momentum is conserved in this example?
Feynman illustrates momentum conservation through a collision of two equal masses, one moving at velocity v and the other at rest. He explains that when these masses collide, they stick together and move with an unknown velocity. By analyzing the situation from a moving reference frame, he shows that the combined mass appears to move at half the initial velocity of the moving mass. This transformation of coordinates reveals that while the two masses stop in one frame, they continue moving at velocity v/2 in another frame. The discussion emphasizes the importance of reference frames in understanding momentum conservation during collisions.
PLAGUE
TL;DR Summary
Two masses moving with same but opposite velocity will stop dead if they collide.
Here is what Feynman says, "Suppose we have two equal masses, one moving with velocity v and the other standing still, and they collide and stick; what is going to happen? There is a mass 2m altogether when we are finished, drifting with an unknown velocity. What velocity? That is the problem. To find the answer, we make the assumption that if we ride along in a car, physics will look the same as if we are standing still. We start with the knowledge that two equal masses, moving in opposite directions with equal speeds v, will stop dead when they collide. Now suppose that while this happens, we are riding by in an automobile, at a velocity -v. Then what does it look like? Since we are riding along with one of the two masses which are coming together, that one appears to us to have zero velocity. The other mass, however, going the other way with velocity v, will appear to be coming toward us at a velocity 2v. Finally, the combined masses after collision will seem to be passing by with velocity v. We therefore conclude that an object with velocity 2v, hitting an equal one at rest, will end up with velocity v, or what is mathematically exactly the same, an object with velocity v hitting and sticking to one at rest will produce an object moving with velocity v/2. "
Feynman said, "two equal masses, moving in opposite directions with equal speeds, will stop dead when they collide." If so, then the car we are riding, moving with velocity -v, and the other mass, moving with velocity v, collide, they must stop dead as their masses are same. Then why do they keep moving with half of the velocity?
https://www.feynmanlectures.caltech.edu/I_10.html
PLAGUE said:
TL;DR Summary: Two masses moving with same but opposite velocity will stop dead if they collide.
That's not what Feynman said about what we see when we ride in the car moving with velocity -v.
Feynman said according to your post ( I highlighted in red the discrepancy)
He is doing a transformation of the coordinates. Let ##v_1\big\rvert_{t<0}## be the velocity of object 1 before the collision, ##v_2\big\rvert_{t>0}## be the velocity of object 2 after the collision, etc. Then, in the reference frame of the center of mass we have $$V_1\Big\rvert_{t<0}=V$$$$V_2\Big\rvert_{t<0}=-V$$$$V_1\Big\rvert_{t>0}=0$$$$V_2\Big\rvert_{t>0}=0$$ where the capital letters indicate quantities in the center of mass frame.
Now, if we have another frame where the center of mass is moving at ##u##, then a simple Galilean transform gives us the velocities $$v_1\Big\rvert_{t<0}=u+V_1\Big\rvert_{t<0}=u+V$$$$v_2\Big\rvert_{t<0}=u+V_2\Big\rvert_{t<0}=u-V$$$$v_1\Big\rvert_{t>0}=u+V_1\Big\rvert_{t>0}=u$$$$v_2\Big\rvert_{t>0}=u+V_2\Big\rvert_{t>0}=u$$
So, we simply apply this formula to the problem. We have before the collision that $$v_1\Big\rvert_{t<0}=u+V_1\Big\rvert_{t<0}=u+V=v$$$$v_2\Big\rvert_{t<0}=u+V_2\Big\rvert_{t<0}=u-V=0$$So we have two equations in ##u## and ##V## which we solve to get ##V=v/2## and ##u=v/2##. Then we simply plug those into the after the collision equations to obtain$$v_1\Big\rvert_{t>0}=u+V_1\Big\rvert_{t>0}=u=v/2$$$$v_2\Big\rvert_{t>0}=u+V_2\Big\rvert_{t>0}=u=v/2$$
This is what he is doing in great detail. He just glossed over the math, but this is the concept he is trying to convey.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
