How high air pressures can a human survive?
  • Thread starter Lojzek
  • Tags
    Air Human
In summary, the maximum pressure at which a human body can function is affected by air pressure and the minimum breathing frequency. Increased pressure can allow a person to hold their breath longer, as seen in scuba divers and those in diving bells. However, at greater depths, the percentage of oxygen in the air must be lowered due to its toxicity. The deepest commercial diving is about 700m, with an experimental dry chamber dive of 3500ft.
Lojzek
249
Does anyone know what is the maximum pressure in which a human body
can function? And how does air pressure affect the minimum breathing frequency?
I suppose increased pressure would allow a person to hold breath longer. For example:
a scuba diver or a person in a diving bell 50m bellow water surface would breathe air that
is about 6 times denser than above surface. If that air had normal oxygen share would it
allow the person to hold breat 6 times as long as above the surface?
Biology news on Phys.org
I think somebody did an experimental dry chamber dive of 3500ft but I can't find the details
The difficulty is that oxygen becomes toxic at high pressures - so as you go deeper you need to lower the percentage of Oxygen.
At 700m you have < %1 O2, since you can't breath this at sea level you have to continually adjust the gas mix as you go deeper.
I can offer some insight into this topic. The maximum air pressure that a human can survive is known as the "crush depth," which is the depth at which the pressure of the water is too great for the body to withstand. This varies from person to person, but on average, a human can survive at a depth of around 500 meters (1640 feet) before the pressure becomes too much for the body to handle. However, this is only if the person is in a pressurized environment, such as a diving bell or a submarine.
In terms of how air pressure affects breathing frequency, it is important to note that humans are adapted to function at a certain range of air pressures. The atmospheric pressure at sea level is around 101 kPa (kilopascals), and this is what our bodies are used to. As the pressure increases, our bodies must work harder to take in the same amount of oxygen. This can lead to an increase in breathing frequency in order to compensate for the higher pressure and maintain proper oxygen levels in the body.
In the example of a scuba diver or a person in a diving bell, the increased pressure does not necessarily allow them to hold their breath longer. While the denser air may make it feel like they can hold their breath longer, the increased pressure actually makes it harder for the body to extract oxygen from the air. This is why divers must carefully monitor their oxygen levels and make sure to breathe regularly while underwater.
In summary, the maximum pressure that a human can survive depends on factors such as individual physiology and the presence of a pressurized environment. As air pressure increases, our bodies must work harder to maintain proper oxygen levels, which can lead to an increase in breathing frequency. However, this does not necessarily mean that a person can hold their breath for longer periods of time at higher pressures.
Related to How high air pressures can a human survive?
1. How high can a human survive without any external support?
The highest altitude that a human can survive without any external support is around 19,000 feet, or 5,800 meters. This is because at high altitudes, the air pressure decreases and there is less oxygen available for the body to function properly.
2. Can humans survive at high altitudes with supplemental oxygen?
Yes, humans can survive at high altitudes with supplemental oxygen. This is because the supplemental oxygen helps to increase the amount of oxygen in the body, making it easier for the body to function properly at high altitudes with lower air pressure.
3. How does the human body adapt to high altitudes?
When humans are exposed to high altitudes, the body goes through a process of adaptation known as acclimatization. This involves the production of more red blood cells, which helps to carry oxygen more efficiently throughout the body. The body also increases its breathing rate to take in more oxygen.
4. What are the risks of high altitude exposure for humans?
The main risks of high altitude exposure for humans include altitude sickness, hypoxia (lack of oxygen), and edema (fluid accumulation in the body). These conditions can be life-threatening if not properly treated.
5. Are there any long-term effects of living at high altitudes?
Yes, there are some potential long-term effects of living at high altitudes. These include chronic mountain sickness, which is characterized by symptoms such as fatigue, headache, and difficulty breathing. There may also be an increased risk of certain health conditions, such as heart disease and stroke, due to the lower oxygen levels at high altitudes.
  • Biology and Medical
13K
  • Classical Physics
