MHB How High Can a 100lb Ball Be Thrown Upwards at 100ft/sec?
  • Thread starter Thread starter Dustinsfl
    Ball
The discussion centers on calculating the maximum altitude a 100lb ball can reach when thrown vertically upward at a velocity of 100 ft/sec. The gravitational acceleration is given as -32 ft/sec². Participants clarify that the weight of the ball does not affect the maximum height, as it cancels out in the energy conservation equation. The relevant formula derived is h = v² / (2g), which indicates that the initial kinetic energy converts entirely into gravitational potential energy at the peak height. Ultimately, the weight of the object is irrelevant in determining the maximum altitude.
Dustinsfl
What is the max altitude when a ball of 100lb is throwing vertically upward with a v = 100 ft/sec?
g = -32ft/sec per sec
I can't figure out how to incorporate the weight.
h(y) = y_0 + v_0t + a\frac{t}{2} = 100t - 16t^2
but can this equation be used? It isn't considering the weight of the object.
Mathematics news on Phys.org
Re: throwing a 100lb ball up
I would use conservation of energy here. The initial energy is all kinetic, while the final energy is all gravitational potential:
$$E_i=E_f$$
$$\frac{1}{2}mv^2=mgh$$
$$h=\frac{v^2}{2g}$$
Note: The weight or mass of the object doesn't matter. As you can see here, it simply gets divided out.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 36 ·
14K
