How is a line integral over any closed surface 0?
In summary, what you are saying is that the line integral over a closed path (where the path is the boundary of a surface) does not always equal 0.
transmini
81
We just started going over line integrals in calculus, and have been told that the integral over any closed surface is 0. What I don't get is then why can we do the line integral of a circle to get 2##\pi##r? Since a circle is a closed surface, shouldn't the line integral then be 0?
You are saying to take the integral of ##\int_0^{2\pi} t d\theta = 2\pi t##. However, if your integrand were a function that viewed ##2\pi ## as 0, ie one which is 2pi periodic, you would also get zero.
Basically, you are comparing two different statements.
One is a loop that begins and ends at the same spot, i.e. integral from 0 to 0, the other is one that does not.
Line integrals are taken over paths. What do you understand by a line integral over a "surface"? If you mean a line integral over the boundary of the surface, then the integral over a boundary of a closed surface vanishes because by definition a closed surface has no boundary.
A circular disc does have a boundary - its circumference.
How could we determine the difference between integrating between 2 different points that are still essentially at the same spot, such as a circle, versus a path that begins and ends at the same point that and comes out to be 0?
This site has the circle on page 2 as being 0 which is part of why I'm confused.
http://ocw.mit.edu/courses/mathematics/18-02sc-multivariable-calculus-fall-2010/3.-double-integrals-and-line-integrals-in-the-plane/part-b-vector-fields-and-line-integrals/session-60-fundamental-theorem-for-line-integrals/MIT18_02SC_notes_29.pdf
I had meant to say paths instead of surfaces but couldn't think of the word for some reason.
line integrals (of one forms) are not always zero over closed paths, but line integrals of "exact" forms over closed paths are zero, i.e. forms of the type df. In fact a one form is exact if amnd only if the integral over every closed path is zero, if and only iof the integral from one point to another along a path is the same for every chpice of path. then one can define the function f as the integral from a fixed point to any other point, choosing any convenient path foe the integration.
a one from Pdx + Qdy is called "closed" if ∂P/∂y = ∂Q/∂x. For these forms, the integral is zero over a closed path that happens to be the boundary of a surface on which the form is defined (and smooth). In particular within a region which is say convex, or simply connected, where every closed path bounda a surface, such closed one forms are also exact. (all smooth exact one forms are closed, by the equality of mixed partials.)
You have to be careful with 'street-corner math'. Random people will say things mathematical, but you are never sure if they have laid all the ground work or specified all the initial conditions which make their statements true.
Always take statements which begin, 'Someone said that ... ' or 'They say that ...' as being suspect until proven otherwise.
Related to How is a line integral over any closed surface 0?
1. What is a line integral over a closed surface?
A line integral over a closed surface is a type of integral in multivariable calculus that calculates the total value of a vector field over the surface. It is a way to measure the flow of a vector field through a given surface.
2. How is a line integral over a closed surface calculated?
A line integral over a closed surface is calculated by breaking the surface into small pieces and approximating the integral as a sum of the values of the vector field at each point on the surface. This sum is then multiplied by the surface area of each small piece and added together to get the total value of the line integral.
3. Why is a line integral over a closed surface often equal to 0?
A line integral over a closed surface is often equal to 0 because the direction of the vector field may be opposite to the direction of the surface normal at certain points, causing the values at those points to cancel out. Additionally, if the vector field is conservative, the line integral over a closed surface will always be 0.
4. What is the significance of a line integral over a closed surface being 0?
A line integral over a closed surface being 0 can indicate that the vector field is conservative, meaning that the work done by the field is independent of the path taken. It can also be used to calculate the flux of a vector field through a closed surface.
5. Can a line integral over a closed surface ever be non-zero?
Yes, a line integral over a closed surface can be non-zero if the vector field is not conservative or if the surface is not a closed surface. In these cases, the line integral represents the work done by the vector field or the flux through the surface, respectively.
  • Calculus
