How is Constant speed of light referenced
In summary, the speed of light is constant for all inertial observers regardless of their relative motion to each other or the source. This is a fundamental postulate of Einstein's special theory of relativity. While distances and time may vary for different observers, they must agree on the speed of light in order to maintain the constancy of c.
Zman
96
The speed of light is constant but with reference to what?
Distances are not absolute and neither is time.
Is it that all inertial observers agree upon the ratio of the distance to the time that it takes for light to go between the two ends of some object even though they don’t necessarily agree upon the length of the object or the time it takes light to traverse that object?
One of the fundamental postulates of Einstein's special theory of relativity is that all inertial observers will measure the same speed of light in vacuum regardless of their relative motion with respect to each other or the source.
I am sure that this statement is definitive but I find it confusing.
I find it confusing because defining speed means defining it with reference to a distance as well as a ‘time span’ and saying that the distance divided by the ‘time span’ is the same for all inertial observers. But distances in SR are not absolute. Different inertial observers will measure different distances for a given object.
You just take the distances and time intervals that are in your equations. The value of c is invariant of the reference frame change.
With reference to every observer measured by rulers and clocks at rest to the observer.
Given that c is an invariant in equations I am trying to interpret it in a physical sense.
For instance, in order to be invariant in different time flows does the speed of light vary with the time flow?
The speed of light is constant with respect to any reference frame. If x beam of light passes both of observors A and B, who are moving a very high speed with respect to each other, each will observe the speed of light to be c in their own reference frame. This in spite of the fact that each observes the other's time to be slowed up.
Another point. If a person standing in the back of a truck, with speed 30 mph relative to you, standing on the side of the road, throws a ball to you at, relative to him, 70 mph, it will hit you with speed, relative to you of (approximately) 30+ 70= 100 mph.
If that same person directs a flashlight at you the light will move away from him at c, in his reference frame, and will move toward you at c, in your reference frame.
That, and the reason I said "(approximately)" before is because the "addition of velocities" formula in relativity is
[tex]\frac{v_1+ v_2}{1+ \frac{v_1v_2}{c^2}}[/tex]
If [itex]v_1[/itex] and [itex]v_2[/itex] are small compared to c, that [itex]v_1v_2/c^2[/itex] will be very small compared to 1 and difference between that and [itex]v_1+ v_2[/itex] will be unmeasurably small. But if [itex]v_2= c[/itex] the formula becomes
[tex]\frac{v_1+ c}{1+ \frac{v_1c}{c^2}}= \frac{v_1+ c}{1+ \frac{v_1}{c}}[/tex]
and, multiplying both numerator and denominator by c,
[tex]= \frac{(v_1+ c)c}{c+ v_1}= c[/tex]
This is basically the right answer. The entire reason observers disagree on distances and times is because they must agree on c. So yes, these differences conspire to keep the observed speed of light c, for all observers.
FAQ: How is Constant speed of light referenced
What is the constant speed of light?
The constant speed of light refers to the speed of light in a vacuum, which is approximately 299,792,458 meters per second or 186,282 miles per second.
How is the speed of light referenced as a constant?
The speed of light is referenced as a constant because it is the same in all directions in a vacuum, regardless of the observer's relative motion. This means that no matter how fast an observer is moving, the speed of light will always be measured as the same value.
Why is the speed of light considered a fundamental constant?
The speed of light is considered a fundamental constant because it is an unchanging value that plays a crucial role in many fundamental theories and laws of physics, such as Einstein's theory of relativity and Maxwell's equations of electromagnetism.
How do scientists measure the speed of light?
There are various methods for measuring the speed of light, such as using mirrors and lasers, or using the time it takes for light to travel a known distance. One of the most accurate methods is using a device called a cavity resonator, which can measure the speed of light to within a few meters per second.
Can the speed of light ever be exceeded?
According to Einstein's theory of relativity, the speed of light is the maximum speed that anything can travel in the universe. Therefore, it is currently believed that the speed of light cannot be exceeded by any object or particle.
