How Is $\delta = \sqrt{9+\epsilon}-3$ the Largest Choice in a Limit Proof?
In summary, the largest possible choice of $\delta$ for proving $\lim_{x\to 3}x^2=9$ is $\delta = \sqrt{9+\epsilon}-3$. This can be verified through a geometric argument by drawing the curve $f(x)=x^2$ and using the square root property to show that $f(3)+\varepsilon=f(3+\delta)$ where $\delta = \sqrt{9+\epsilon}-3$.
Dethrone
717
Verify, by a geometric argument, that the largest possible choice of $\delta$ for showing that $\lim_{{x}\to{3}}x^2=9$ is $\delta = \sqrt{9+\epsilon}-3$
I have no clue, hints?
With $f(x)=x^2$, I would begin with:
\(\displaystyle f(3)+\varepsilon=f(3+\delta)\)
I can expand it...
$f(3+\delta)=9+6\delta +(\delta)^2$, but I still don't see a geometric argument from that :(
Draw the curve $f(x)=x^2$. Now, on the $x$-axis at $x=3$, draw a vertical line segment up to the curve. Where this line touches the curve, draw a horizontal line segment to the left, until it reaches the $y$-axis...this is $f(3)$. Now, go back to the vertical line, and choose a distance $\delta$ from $x=3$, which will be $3+\delta$. Draw a line up to the curve, and the to the left to the $y$-axis. It will be at $f(3)+\varepsilon$. Thus we see from this construction, that we must have:
\(\displaystyle 9+\varepsilon=(3+\delta)^2\)
Instead of expanding, use the square root property, and take the positive root, and you will have shown what is required. :D
FAQ: How Is $\delta = \sqrt{9+\epsilon}-3$ the Largest Choice in a Limit Proof?
What is an epsilon proof?
An epsilon proof, also known as an epsilon-delta proof, is a type of mathematical proof used to show that a limit exists. It involves choosing a small number (epsilon) and showing that for any input value (delta) within a certain distance of the limit, the output value will be within epsilon of the limit.
How is an epsilon proof used in geometry?
In geometry, an epsilon proof is used to prove the existence of a limit or to show that a geometric concept or theorem is true. It can also be used to find the value of a limit or to prove that a limit is equal to a specific value.
What is the significance of using epsilon in an epsilon proof?
Epsilon is a small, positive number that represents the margin of error in an epsilon proof. It allows for a more precise definition of a limit, as it shows that the output value can be made as close as desired to the limit by choosing an input value within a certain distance (delta) of the limit.
What are the steps involved in an epsilon proof?
The steps involved in an epsilon proof are as follows:
  1. Choose an epsilon value (a small, positive number).
  2. Write the definition of the limit using epsilon and delta.
  3. Manipulate the definition to find a relationship between delta and epsilon.
  4. Choose a delta value based on the relationship found in the previous step.
  5. Show that for any input value within delta of the limit, the output value will be within epsilon of the limit.
What are some common applications of epsilon proofs?
Epsilon proofs are commonly used in calculus and real analysis to prove the existence of limits, continuity of functions, and convergence of sequences and series. They are also used in physics, engineering, and other fields that involve mathematical modeling and analysis.
