How is energy transferred from the bicycle wheel?
In summary: Presumably the man has to work just as hard, but now the turntable stops.Where has the energy gone?The energy has been transferred back to the cyclist's muscles.
Michio Cuckoo
84
https://www.youtube.com/watch?v=V3UsrfHa4MQ
So check out the above video.
When the man flips the bicycle wheel over, the turntable he is sitting on starts to rotate. What I don't understand is, how is energy transferred from the bicycle wheel to the turntable?
Energy isn't transferred from the bicycle wheel to the turntable. Just angular momentum.
But where does the turntable get the energy to rotate?
From the muscles of the man.
In order to turn the wheel through a right angle, the man must apply force to ends of of the axle. You can trace trace the reaction force through the man's muscles and skeleton to his feet braced on the turn table (obviously, if he were standing on frictionless ice or in space, the motion would be different.)
Yes, the forces (or rather torques) are transferring angular momentum from the wheel to the turn table. But there is no energy transferred from the wheel to the turn table.
On ice it would be quite similar to the turn table.
quite a sneaky transfer of energy. Thanks for explaining.
So what happens if he flips the wheel back again? Presumably the man has to work just as hard, but now the turntable stops. Where has the energy gone?
FAQ: How is energy transferred from the bicycle wheel?
Energy is transferred from the bicycle wheel through a process called mechanical energy transfer. This occurs when a force, such as pedaling, is applied to the pedals of the bicycle. The pedals then turn the crank, which is connected to the chain and ultimately the rear wheel. As the rear wheel rotates, it transfers energy to the bike's motion, propelling it forward.
What type of energy is transferred from the bicycle wheel?
The type of energy transferred from the bicycle wheel is kinetic energy. Kinetic energy is the energy an object possesses due to its motion. In the case of a bicycle wheel, the rotating motion of the wheel translates to the forward motion of the bike, making it an example of kinetic energy transfer.
Is energy loss possible during the transfer from the bicycle wheel?
Yes, energy loss can occur during the transfer from the bicycle wheel. Friction and air resistance can cause some of the energy from the wheel to be converted into heat and sound. This loss of energy can result in a decrease in the bike's speed and efficiency.
Can energy be transferred to the bicycle wheel?
Yes, energy can also be transferred to the bicycle wheel. This occurs when the bike is coasting downhill or when brakes are applied, converting the bike's kinetic energy back into potential energy. The potential energy is then used to slow down or stop the bike.
How can we improve the efficiency of energy transfer from the bicycle wheel?
There are several ways to improve the efficiency of energy transfer from the bicycle wheel. One way is by reducing friction in the bike's moving parts, such as lubricating the chain and gears. Another way is by using aerodynamic designs to reduce air resistance. Additionally, maintaining proper tire pressure can also improve the efficiency of energy transfer from the bicycle wheel.
