How is isobaric process physically possible?
In summary: FIn summary, an ideal gas enclosed in a cylinder with a piston of weight ##mg## on top will have a force of ##F=PA## acting on the piston when the system is at rest. If the gas undergoes an isobaric process, where temperature and volume increase while pressure is held constant, the piston will continuously change its position and be subject to a net force. However, as long as the process is slow enough, the gas pressure will remain virtually identical to the external pressure, which is constant. This makes an isobaric process possible despite the confusion of the piston's changing position.
Omar Nagib
We have an ideal gas enclosed in cylinder whose top is covered by a piston of certain weight ##mg##. At this stage, the piston is at rest which means the force by which the gas acts on the piston (##F=PA## where ## P## is the gas pressure and ##A## is the cross sectional area of the cylinder) is equal to ##mg##.
Now if this system was subject to an isobaric process, then its temperature and volume changes with its pressure held constant(suppose ##T## and ##V## increase). But this is confusing, since during the process the piston is continuously changing its position, which implies its being acted upon by a certain net force; Now the weight of the piston ##mg## is constant, so the force ##F=PA## by which the gas acts on the piston must have increased, but since ##A## is constant, therefore ## P## must have increased; therefore ##P## is not constant.
So How isobaric process is physically possible?
The external pressure (atmospheric pressure + mg/A) is constant. So the gas pressure just has to be a tiny bit greater than this in order to expand. You just have to have a process that is slow enough so that there is no significant acceleration (ie. keeping acceleration small so that adding ma/A<<mg/A). For example, if the process is an isobaric expansion caused by heat flow into the gas, the rate of heat flow must be sufficiently slowly so that temperature and volume increases slowly. That way, the gas pressure remains virtually identical to external pressure, which is constant.
AM
Related to How is isobaric process physically possible?
1. How does an isobaric process maintain constant pressure?
An isobaric process maintains constant pressure by allowing the system to exchange heat with its surroundings. This means that as the volume of the system changes, the pressure remains constant due to the transfer of heat.
2. Does an isobaric process always involve a gas?
No, an isobaric process can involve any substance that can transfer heat and maintain constant pressure. This can include liquids, solids, and gases.
3. How is a piston used in an isobaric process?
A piston is used in an isobaric process to maintain a constant pressure by allowing the volume of the system to change while keeping the pressure constant. As the volume of the system increases, the piston will move outwards, and vice versa.
4. What is the relationship between temperature and pressure in an isobaric process?
In an isobaric process, the relationship between temperature and pressure is directly proportional. This means that as the temperature of the system increases, the pressure also increases.
5. Can an isobaric process be reversed?
Yes, an isobaric process can be reversed, meaning that the system can go from a higher volume to a lower volume while maintaining constant pressure. This is known as an isobaric compression process.
  • Other Physics Topics
  • Classical Physics
