How is light produced in the following?
In summary, electricity flows through tungsten wires in incandescent light bulbs, causing the filament to get hot and emit light through black body radiation. Tungsten is used because it is a durable, conductive metal with a high melting point.
Biologik
38
I don't know how Electricity is able to conduct light, please be detailed.
Liht Bulbs
Incandescent bulbs
I just wonder how electricity flows through the Tungsten wire (why is the wire tungsten) and can cause light to be emitted.
Science news on Phys.org
Electricity flows through tungsten (and other metals) because many of the electrons are not bound to just one atom, and can easily move around throughout the metal.
The wire in incandescent bulbs is made from tungsten because tungsten is durable, conducts electricity, and has a high melting point.
FAQ: How is light produced in the following?
How is light produced in an incandescent light bulb?
Light is produced in an incandescent light bulb through a process called incandescence. This is when a material, such as a tungsten filament, is heated to a high temperature, causing it to emit light.
How is light produced in a fluorescent light bulb?
Light is produced in a fluorescent light bulb through a process called fluorescence. Inside the bulb, there is a small amount of mercury vapor and an inert gas. When electricity is passed through the gas, it excites the mercury vapor, which then emits ultraviolet light. This ultraviolet light then hits a phosphor coating on the inside of the bulb, causing it to emit visible light.
How is light produced in a LED light bulb?
Light is produced in a LED light bulb through a process called electroluminescence. Inside the bulb, there is a semiconductor material, typically made of silicone, that has been doped with impurities. When a current is passed through the semiconductor, it causes electrons to move from one side to the other, releasing energy in the form of light.
How is light produced in a laser?
Light is produced in a laser through a process called stimulated emission. Inside the laser, there is a material, such as a crystal or gas, that is excited by an external energy source, such as electricity or light. This excitation causes photons to be emitted, which then travel through a cavity that contains mirrors. As the photons bounce back and forth between the mirrors, they stimulate other excited atoms to emit photons, creating a beam of light.
How is light produced in the sun?
Light is produced in the sun through a process called nuclear fusion. In the sun's core, hydrogen atoms are fused together to form helium atoms, releasing vast amounts of energy in the form of light and heat. This process, known as the proton-proton chain, is what powers the sun and allows it to emit light.
