How is Rodrigue's Formula Derived?
  • MHB
  • Thread starter danny12345
  • Tags
    Formula
In summary, Rodrigue's formula is a mathematical formula named after Olinde Rodrigues used to calculate the derivative of a complex function. It is derived using the chain rule, product rule, and quotient rule and is significant because it allows for faster and more efficient calculations. However, it can only be applied to differentiable complex functions and has limitations in finding higher order derivatives and applying to more complex functions.
danny12345
how do we derive rodrigue's formula
Hi dansingh,
Welcome to MHB! The method of deriving this is given at this link;
Legendre polynomials and Rodrigues' formula
Let us know if you have any further questions with the derivation. :)
n(x)=(x2-1)n. (20)
By differentiation we see that it satisfies the following first order differential equation,
(1-x2)f'n+2nxfn=0.
how did you get itb pleasez explain me the differentiation part
FAQ: How is Rodrigue's Formula Derived?
What is Rodrigue's formula?
Rodrigue's formula is a mathematical formula used to calculate the derivative of a complex function. It is named after French mathematician Olinde Rodrigues.
How is Rodrigue's formula derived?
Rodrigue's formula is derived using a combination of the chain rule, product rule, and quotient rule. It is a complex calculation that requires a strong understanding of calculus.
What is the significance of Rodrigue's formula?
Rodrigue's formula is significant because it allows us to calculate the derivative of a complex function without having to use the limit definition of a derivative. This can save time and make calculations more efficient.
Can Rodrigue's formula be applied to all functions?
No, Rodrigue's formula can only be applied to differentiable complex functions. It cannot be used for functions with discontinuities or non-differentiable points.
Are there any limitations or drawbacks to using Rodrigue's formula?
One limitation of using Rodrigue's formula is that it cannot be used to find higher order derivatives. It also requires a strong understanding of calculus and can be difficult to apply to more complex functions.
