How is the Change in Limits from (1) to (3) in this Calculus Problem Explained?
In summary: Thus we have the region $D = \{(x,y) | x \in [0, y^3],$ $y \in [0,2]\}.$In summary, the limits of integration were changed from (1) to (3) in order to make the integration process easier and to allow for the use of elementary anti-derivatives. This change also better reflects the given region of integration, which is above and to the left of the graph of $y=\sqrt[3]{x}$.
karush
MHB
3,269
\begin{align}\displaystyle
&=\int_{0}^{8}\displaystyle \int_{\sqrt[3]{x}}^{2}
\frac{dydx}{y^4+1}&&(1)\\
&\qquad D: 0\le x \le 8, \quad \sqrt[3]{x}\le y\le 2 &&(2)\\
&=\int_{0}^{2}\int_{0}^{y^3}
\frac{1}{y^4+1} \, dxdy&&(3)\\
&=\int_{0}^{2}\frac{y^3}{y^4+1} \, dy&&(4) \\
&=\frac{1}{4}(y^4+1)\biggr|_{0}^{2}&&(5)\\
&=\color{red}{\frac{1}{4}\ln{17}}
\end{align}
ok this was the solution that was given
but I don't understand the change in limits from (1) to(3)
$\tiny{t15.2.54}$
\end{align}
$\tiny{t15.2.54}$
In the first quadrant:
$y = \sqrt[3]{x}$
$x = y^{3}$
Paint the region two different ways.
Vertical Stripes vs. Horizontal stripes.
In the first integral, x goes from 0 to 8 and, for each x, y goes from $\sqrt[3]{x}$ to 2. That region is above and to the left of the graph of $y= \sqrt[3]{x}$. So, overall, y goes from 0 up to 2 and, for each y, x goes from 0 to $y^3$.
so what is the advantage of thst?just easier numbers?
Sometimes, simply changing the order will take a problem from impossible to trivial.
As originally written the first integral, \(\displaystyle \int \frac{dy}{y^4+ 1}\), does not have an anti-derivative in elementary terms. But changing the order of integration, the anti-derivative of \(\displaystyle \int \frac{dx}{y^4+ 1}\) is just \(\displaystyle \frac{x}{y^4+ 1}\). And since the limits of integration are 0 and \(\displaystyle y^3\), the next integral is \(\displaystyle \int \frac{y^3 dy}{y^4+ 1}\) which is easy- use the substitution \(\displaystyle u= y^4+ 1\).
By the way- there is a typo in the fifth line of your first post: It should be \(\displaystyle \frac{1}{4}ln(y^4+ 1)\). You dropped the "ln".
We have the $y \in [\sqrt[3]{x}, 2]$ and $ x \in [0,2]$. Now $\sqrt[3]{x} \le y \implies x \le y^3$ for $x \in [0,2]$. But also $0 \le x$.
Thus $x \in [0, y^3].$ Also if the minimum value of $x =0$ then $y \in [0,2].$ Hence $x \in [0, y^3],$ $y \in [0,2].$
FAQ: How is the Change in Limits from (1) to (3) in this Calculus Problem Explained?
1. What does "15.2.54 change in limits" refer to?
The phrase "15.2.54 change in limits" typically refers to a change in the numerical limits or boundaries of a specific system or process. It can also refer to a change in the rules or regulations governing these limits.
2. Why is there a need for a change in limits?
There can be various reasons for a change in limits, including new scientific discoveries, changes in technology, or shifts in societal or environmental factors. These changes may require re-evaluation and adjustment of existing limits to ensure safety, efficiency, or effectiveness.
3. How are new limits determined?
The process of determining new limits is usually based on extensive research, data analysis, and risk assessment. It may involve collaboration between scientists, policy-makers, and stakeholders to gather and evaluate relevant information and make informed decisions.
4. What are the potential impacts of a change in limits?
The impacts of a change in limits can vary depending on the specific context and purpose. In some cases, it may lead to improved performance, increased safety, or better resource management. However, it may also cause disruptions, resistance, or unintended consequences, which need to be carefully evaluated and managed.
5. How often do limits need to be changed?
The frequency of changes in limits can vary significantly depending on the nature of the system or process. In some cases, limits may need to be regularly reviewed and adjusted to keep up with advancements or changing conditions. In other cases, limits may remain relatively stable over long periods of time.
