How is the CSCO in an harmonic oscillator?
In summary, the conversation discussed finding the constants of motion and the complete set of commuting observables to solve the Hamiltonian for a mass with spin 1/2 subject to a central potential. The term "CSCO" was defined as the Complete Set of Conmuting Observables. The group also discussed the use of Cartesian coordinates and phonon-number operators as a complete set, as well as using the Hamiltonian, angular momentum, and spin as constants of motion.
Dario SLC
Hi everyone, I have a great doubt in this problem:
Let a mass m with spin 1/2, subject to the following central potencial V(r):
V(r)=1/2mω2r2
Find the constants of motion and the CSCO to solve the Hamiltonian?
This is my doubt, I can't find the CSCO in this potencial. Is a problem in general quantum physics, not use the Dirac's notation brakets and ket.
Thanks a lot!
Dar
What the heck is CSCO? Define your acronyms!
Yes I am sorry, CSCO= Complete Set of Conmuting Observables. This I need for resolve the hamiltonian.
It's the same set as with a hydrogen atom, as this is rotation symmetric. Isn't that term just a "centrifugal" force that actually belongs to the kinetic energy but can also be thought of as an effective noninertial part of the potential field?
For the symmetric 3D harmonic oscillator you have of course several possibilities. On one hand you can use Cartesian coordinates and use the three phonon-number operators ##\hat{N}_j=\hat{a}_j^{\dagger} \hat{a}_j## as the complete set. The relation to the Hamiltonian is
$$\hat{H}=\hbar \omega \left (\sum_{j=1}^3 \hat{N}_j+\frac{3}{2} \right ).$$
On the other hand, as any central potential you can as well use ##\hat{H}##, ##\hat{\vec{L}}^2##, and ##\hat{L}_z## as the complete set. The corresponding quantum numbers are then as for any central potential ##E##, ##\ell## and ##m##.
Ok thanks a lot!
Then in addition, the ##\hat{L}_z## and ##\hat{L}^2## they are motion constants because the hamiltonian is invariant to rotations and translations, and the energy ##E## only depends of the quantum number ##n##just because the hamiltonian conmute with the operator rotator ##\hat{R}## and translator ##\hat{T}##. It is true no?
Hi, a question about the spin, this add a new constant of movement, ie., in addition to ##L^2##, ##L_z## and ##H##, ##S_z## also is a constant of movement? My doubt is because this problem have in reality four constant of movement if we take into account that spin.
Related to How is the CSCO in an harmonic oscillator?
1. How does the mass affect the CSCO in a harmonic oscillator?
The mass does not affect the CSCO (Classical Simple Harmonic Oscillator) in any way. The CSCO is solely dependent on the stiffness of the spring and the frequency of the oscillation.
2. What is the equation for the CSCO in an harmonic oscillator?
The equation for the CSCO in an harmonic oscillator is given by CSCO = 2π√(m/k), where m is the mass and k is the stiffness of the spring.
3. How does the stiffness of the spring affect the CSCO in an harmonic oscillator?
The stiffness of the spring has a direct impact on the CSCO in an harmonic oscillator. As the stiffness increases, the frequency of oscillation also increases, resulting in a larger CSCO.
4. Can the CSCO in an harmonic oscillator be altered?
Yes, the CSCO in an harmonic oscillator can be altered by changing the stiffness of the spring or by changing the frequency of oscillation. Additionally, the CSCO can also be affected by factors such as damping and external forces.
5. What is the significance of the CSCO in an harmonic oscillator?
The CSCO is significant as it represents the maximum displacement of the oscillating object from its equilibrium position. It also helps in understanding the behavior and characteristics of the harmonic oscillator system.
