How is the energy of an electron lost in a classical hydrogen atom?
In summary, the hydrogen atom is unstable under classical physics due to the accelerating electron losing its kinetic energy as electromagnetic radiation. While it is commonly thought that this energy must come from the internal energy of the atom, this is not necessarily the case. The energy can come from external sources, such as the work done by external forces on the atom. The concept of a point particle is also not valid in this scenario, as shown by the derivation of the Larmor formula. Attempts to introduce radiation reaction forces on microscopic particles have not led to a consistent theory. Even if we allow for the electron to have a non-zero size, the force responsible for its recoil would be the interaction between different parts of the electron. However, this is difficult to calculate
jfizzix
Insights Author
355
Consider the following.
You have an electron of negative charge orbiting a proton of positive charge at some distance R (i.e. a classical hydrogen atom).
I understand the hydrogen atom is unstable under classical physics because the accelerating electron loses its kinetic energy as electromagnetic radiation.
My question is set up as follows.
All you have is the proton acting on the electron.
In the rest frame of the proton, the electric field is constant, extending radially outward, so that it can do no work on the electron,
In the rest frame of the proton, there is no magnetic field on the electron due to the proton either.
What field is slowing down the electron?
Any comments would be appreciated, as this has puzzled me for quite come time.
Why wouldn't the electric field be able to do work? I'm pretty sure a static electric field will easily perform work on charges.
the electric field can't do work on the electron because the field on the electron is always perpendicular to the direction the electron is moving, making the dot product of force with instantaneous displacement zero.
What about the electric and magnetic fields created by the electron?
It is usually thought so on the basis of Larmor's formula for radiated energy and the idea that the radiated energy has to come from the internal energy of the atom. This argument does not work with forces, and attempts to introduce such radiation reaction forces acting on the microscopic particles did not lead to a consistent theory.
However, neither of the above two assumptions is necessary; the derivation of the Larmor formula is not valid for point particles and even if the system of charges radiates, the energy does not need to come from inside the system - it can come from other sources. For example, it can come from the work external forces do on the atom.
An antenna is a good example daily life - it radiates but it does not lose energy.
Approximate numerical calculations of the trajectory of the electron in fluctuating electromagnetic field seem to support this picture. For example, see the paper: D. C. Cole, Yi Zou, Quantum mechanical ground state of hydrogen obtained from classical electrodynamics, Physics Letters A 317 (2003), p. 14–20.
http://dx.doi.org/10.1016/j.physleta.2003.08.022
If we assume the hydrogen atom is isolated, the energy can only come from either the electron or the proton, or the fields generated by them. Maybe if we consider the particles to be of nonzero size, we can discuss the effect of one part of the electron on the rest of it as it orbits the nucleus, but it's not clear to me how this would work out mechanically.
An antenna loses energy as quickly as it's replaced by an electric power source.
So if we allow the electron to be a fuzzball or sphere of nonzero size, what force would then be responsible for the recoil the electron experiences?
Yes. But then again, the atom is impossible to isolate; there are always electromagnetic fields present.
Yes, but it would be very difficult in general - we would have to introduce non-electromagnetic forces. There are attempts based on approximations of "rigid sphere". See the book by Yaghjian (there is a possibility to view few pages).
http://www.springer.com/physics/optics+&+lasers/book/978-0-387-26021-1
In a sense, the force of one part of electron on another. The Lorentz-Abraham expression for "radiation reaction force" is an approximate result of this idea.
Related to How is the energy of an electron lost in a classical hydrogen atom?
1. How is the energy of an electron lost in a classical hydrogen atom?
The energy of an electron in a classical hydrogen atom can be lost in several ways. One common way is through the emission of a photon when the electron transitions from a higher energy level to a lower energy level. This process is known as spontaneous emission. Another way is through collisions with other particles, which can cause the electron to lose energy and change its trajectory.
2. Does the energy of an electron in a classical hydrogen atom ever reach zero?
No, the energy of an electron in a classical hydrogen atom does not reach zero. According to the Bohr model, the electron can only occupy certain discrete energy levels. And according to quantum mechanics, even at the lowest energy level, known as the ground state, the electron still has some non-zero energy due to its inherent motion.
3. Can the energy of an electron in a classical hydrogen atom be regained?
Yes, the energy of an electron in a classical hydrogen atom can be regained through absorption of a photon. When the electron absorbs a photon, it gains energy and transitions to a higher energy level. This process is known as absorption or stimulated emission.
4. Are there any other factors that can cause the energy of an electron in a classical hydrogen atom to decrease?
Aside from spontaneous emission and collisions, the energy of an electron in a classical hydrogen atom can also decrease due to external factors such as external electric or magnetic fields. These fields can alter the electron's trajectory and cause it to lose energy as it interacts with other particles or the atom itself.
5. How does the energy of an electron in a classical hydrogen atom relate to its position?
The energy and position of an electron in a classical hydrogen atom are related through the Heisenberg uncertainty principle. This principle states that it is impossible to know the exact position and energy of an electron simultaneously. As the energy of the electron increases, its position becomes more uncertain. This uncertainty in position also applies to the electron's trajectory, making it difficult to predict where the electron will be at any given time.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
