How is the energy tranported at a certain time and point?
The discussion addresses how energy is transported in electromagnetic waves, specifically focusing on the relationship between electric and magnetic fields. It explains that the direction of propagation remains unchanged even when the electric field changes, as determined by the right-hand rule. The magnetic field's shift to the negative y direction in the second half of the cycle does not alter the propagation direction. The mathematical representation of this relationship is given by the vector product of the electric field (E) and magnetic field (B). An animation is provided to illustrate the concept effectively.
hidemi
At a certain point and a certain time the electric field of an electromagnetic wave is in the negative z direction and the magnetic field is in the positive y direction. Which of the following statements is true?
A. Energy is being transported in the positive x direction but half a cycle later, when the electric field is in the opposite direction, it will be transported in the negative x direction
B. Energy is being transported in the positive x direction and half a cycle later, when the electric field is in the opposite direction, it will still be transported in the positive x direction
C. Energy is being transported in the negative x direction but half a cycle later, when the electric field is in the opposite direction, it will be transported in the positive x direction
D. Energy is being transported in the negative x direction and half a cycle later, when the electric field is in the opposite direction, it will still be transported in the negative x direction
E. None of the above are true
Answer: B
E = v*B
I get the first part of B, but why doesn't the transported direction not change as the electric field changes? Does it follow the right-hand rule?
In the second half of the cycle, the magnetic field will have changed to the negative y direction. So applying the right-hand rule leaves the direction of propagation unchanged.
You can see the process in this animation ('play button' is on the bottom left): https://ophysics.com/em3.html)
Mathemtically speaking, the direction of propagation is the direction of the vector product ##\vec E \times \vec B##.
Thanks for the amazing animation! I got it!
Likes Steve4Physics
