How is the Gamma Function Related to Factorials?
In summary, the problem is that I'm not understanding how to solve for \(n\) in the equation \(\Gamma(n)\).
skate_nerd
176
I've got this funny looking problem for calculus II due tomorrow that I've been stumped on all week. It comes with three parts, and starts by stating:
Define for any \(r\geq0\) (real):
\(\Gamma(r)=\int_{0}^{\infty}{x^r}{e^{-x}}\,dx\)
a. Show that \(\Gamma(0)=1\)
This one was relatively easy. Just plugged in 0 to the r in the integral and got the answer 1.
b. Show that for any \(r\geq0\):
\(\Gamma(r+1)=(r+1)\Gamma(r)\)
When I tried solving for this all I seemed to be able to figure out was to plug the integral that is equal to \(\Gamma(r)\) into the right side of the equation, but from there I really just have no idea what to do with the \(\Gamma(r+1)\).
and if we can get there...
c. Conclude that for any \(n\in N\) (real):
\(\Gamma(n)=n!\)
I feel like solving b might give insight to this problem, but right now all I can say is that I have no idea how a third variable "n" just came into this problem.
\(\Gamma(n)=n!\)
Hint for b.: use integration by parts on $\Gamma(r+1)$.
Hint for c.: induction.
b) $\displaystyle \Gamma(r+1)=\int_0^{\infty}x^{r+1}e^{-x}\,dx$
Using IBP, we may define:
$\displaystyle u=x^{r+1}\,\therefore\,du=(r+1)x^r\,dx$
$\displaystyle dv=e^{-x}\,\therefore\,v=-e^{-x}$
and we have...?
edit: pipped at the post! (Tmi)
Thanks for the responses, still a little confused though.
I tried working out the integration by parts for myself and ended up with this:
\(\int_{0}^{\infty}x^{r+1}e^{-x}=-e^{-x}x^{r+1}+(r+1)\int_{0}^{\infty}x^re^{-x}\)
It seems like I'm on the right track but I guess I am overlooking something.
What you have is actually:
$\displaystyle \int_{0}^{\infty}x^{r+1}e^{-x}=\left[-e^{-x}x^{r+1} \right]_0^{\infty}+(r+1)\int_{0}^{\infty}x^re^{-x}\,dx$
Woops! Guess I've never thought to solve that part out with its bounds without solving the whole integral yet.
Anyways, solving that out, I got zero, and that in turn proves what I needed to prove. Thanks a bunch!
One last question, how do you make those longer integral symbols in Latex? They look a lot nicer than these little ones... \(\int f(x) dx\)
I use the tags
Code:
$\displaystyle insert LaTeX code here$
Sorry, I just realized I still have no idea how to start part c. Can I just plug in n into \(\Gamma(r)\) ? I still just can't really see any way of relating that integral \(\Gamma(n)\) to n!.
\(\Gamma(n)=n!\)
In order to avoid misunderstanding the 'Gamma Function' is usually defined as...
$\displaystyle \Gamma (r) = \int_{0}^{\infty} x^{r-1}\ e^{- x}\ dx$ (1)
... and the 'Factorial Function' as...
$\displaystyle r! = \int_{0}^{\infty} x^{r}\ e^{- x}\ dx$ (2)
The properties of course are very similar, but it is important don't have confusion. Your example implies the Factorial Function... Kind regards $\chi$ $\sigma$
You have stated that:
$\displaystyle n\in\mathbb{N}$
but have (real) after it. I am assuming we are to let n be a natural number instead.
I would begin the proof by induction by demonstrating the validity of the base case:
$\displaystyle \Gamma(1)=1!$
Using the result from part b) we may state:
$\displaystyle \Gamma(0+1)=(0+1)\Gamma(0)$
Using the result from part a) we now have:
$\displaystyle \Gamma(1)=1=1!$
So, the base case is true. Now, state the induction hypotheses $\displaystyle P_k$:
$\displaystyle \Gamma(k)=k!$
From part b) we know $\displaystyle \Gamma(k)=\frac{\Gamma(k+1)}{k+1}$
Now, substitute to finish the proof by induction.
Thanks for all that you guys. And yes I don't know why I put real I did in fact mean natural. I feel like this teacher assumes we all took a class on proofs, but I haven't learned any of these things yet! Guess I'm going to have to take that class soon.
Induction is sometimes taught in Precalculus, but I suppose it may be optional and up to the discretion of the instructor.
It is a very useful method, and I recommend if you have spare time to give it a look. (Handshake)
FAQ: How is the Gamma Function Related to Factorials?
What is a series defined as an integral?
A series defined as an integral is a mathematical concept that involves finding the sum of infinitely many terms by using integration. It is typically represented by the notation ∫f(x)dx, where f(x) is the function being integrated.
How is a series defined as an integral different from a regular series?
A regular series involves adding together a finite number of terms, while a series defined as an integral involves adding together an infinite number of terms. Additionally, a series defined as an integral uses integration to find the sum, while a regular series uses addition.
What is the significance of using integration in a series?
Using integration in a series allows for the sum of infinitely many terms to be found, which would not be possible using regular addition. This allows for more complex and precise calculations in mathematics and science.
Can a series defined as an integral have a finite sum?
Yes, a series defined as an integral can have a finite sum. This occurs when the function being integrated approaches zero as x approaches infinity, resulting in a finite value for the sum.
What are some real-life applications of series defined as an integral?
Series defined as an integral can be found in various fields such as physics, engineering, and economics. For example, they are used to calculate the area under a curve in physics and to model population growth in biology. In economics, they are used to calculate the net present value of investments.
