B How is the harmonic mean affected by additional data points?
The discussion centers on the impact of adding new data points on the harmonic mean (HM) of an existing dataset. Initially, a dataset of eight points has a harmonic mean of 22.86, which increases to 23.08 after adding two additional points. It is noted that the harmonic mean is influenced by the relative values of new points compared to the existing mean; points below the HM decrease it, while points above increase it. The conversation concludes that the combined harmonic mean of two datasets can be calculated using a weighted formula, confirming that the overall HM will shift based on the new data's harmonic mean. Understanding these relationships allows for predictions about how the HM will change with additional data points.
Feynstein100
We have a collection of 8 discrete data points. They are:
10, 20, 30, 20, 30, 40, 30, 40
In increasing order:
10, 20*2, 30*3, 40*2
The harmonic mean of this data series is 22.86
I read on Wikipedia that the harmonic mean is skewed towards the smaller values i.e. smaller values will affect the HM more than larger values. So I thought that if we add 2 additional data points 20 and 30, our HM would be even smaller. And yet, when I calculated the HM of this new data series with 10 points:
10, 20*3, 30*4, 40*2
it turned out to be 23.08 i.e. higher than the previous case. Why did that happen?
One of our new points was lower than the HM whereas the other was higher. I thought the HM would be more skewed toward the lower value and thus would bring the overall mean down. Ah is it because the second datapoint was much higher than the HM?
In general, I'm interested in the question of how adding new datapoints will affect the HM of the existing data series.
We're not changing the endpoints, they remain constant. So any new point added will lie somewhere inside the bounds of the data series. In our example, that's 10 and 40.
So I think the answer is quite simple. If New point < HM, it lowers the HM. If New point > HM, it increases the HM.
It seems quite straightforward for adding one datapoint but what if we add multiple? In essence appending another data series to the existing one. Can we predict in advance if the new HM will be higher or lower?
Mathematics news on Phys.org
It looks like a simple quantitative question. One point at a time will give a predictable result. More than one - results?
Yes. If the harmonic mean of the new points is lower, the HM of all the points will be lower, If it is higher the new HM will be higher. Easy to see from HM of \frac {1}{\sum {\frac{1}{a_i}}} and \frac {1}{\sum {\frac{1}{b_i}}} is \frac {1}{ \sum {\frac{1}{a_i}} + \sum {\frac{1}{b_i}} }
Likes Feynstein100
That's............kind of what I'm asking 😂
Thanks for the reply. I worked it out myself and turns out, the combined harmonic mean Hc of two harmonic means H1 with m items and H2 with n items will be
Hc =(m + n)/(m/H1 + n/H2)
i.e. the weighted harmonic mean of H1 and H2. And by the general property of all means, Hc will be somewhere between H1 and H2. Thus, if the new HM is lower, the overall HM will be lower as well. And if the new HM is higher, the overall HM will be higher as well.
Btw your third formula has a mistake. It should be 2/(sum of inverses), not 1/(sum of inverses) and that's a special case of when both series have the same number of items. The general formula is the weighted harmonic mean.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
