How Is the Integral of sqrt(y^2-16)/y Solved Using Trigonometric Substitution?
  • MHB
  • Thread starter karush
In summary, the conversation discussed the integral $\displaystyle I_{31}=\int \frac{\sqrt{y^2-16}}{y} \, dy$, with the answer provided by maxima as $I_{31}=4\arcsin \left[\frac{4}{y}\right]+\sqrt{y^2-16}+C$. The conversation also mentioned using trigonometric substitution and an identity to simplify the integral. A suggested manipulation of the integrand was also provided to make the substitutions more apparent.
karush
MHB
3,269
Given (answer by maxima)
$$\displaystyle
I_{31}=\int \frac{\sqrt{y^2-16}}{y} \, dy =
4\arcsin\left(\dfrac{4}{\left|y\right|}\right)+\sqrt{y^2-16}+C
trig subst
$$y=4\tan\left({\theta}\right)
\therefore dy=4\sec^2 (\theta)d\theta$$
so
$$\displaystyle I_{31}=4\int\frac{\sec^3(\theta)}{\tan\left({\theta}\right)}\,d\theta$$
kinda ?
It seems you are implying that:
\(\displaystyle \sec^2(\alpha)=\tan^2(\alpha)-1\)
and that's not an identity. :D
$$\displaystyle
trig substitution use identity $\tan^2\theta = \sec^2\theta - 1 $
$$y=4\sec\left({\theta}\right)
\therefore dy=4\sin\theta\sec^2 (\theta) \, d\theta \\
\displaystyle\theta=\sec^{-1}\left(\frac{y}{4}\right)$$
so
$$\displaystyle
I_{31}=\int\frac{\sqrt{16 \sec^2{\theta}-16}}{4\sec\theta}4\sin\theta\sec^2\theta \,d\theta
=4\int\tan^2\left({\theta}\right) \, d\theta$$
so far ?
Looks good so far...:D
$$\displaystyle
identity
so
$$\displaystyle
$$=\frac{-4
\left[\theta \cos\left({\theta}\right)-\sin\left({\theta}\right)
\right]}
{\cos\left({\theta}\right)}
=-4\theta +\tan\left({\theta}\right)+C $$
back subst $\theta=
$$I_{31}=-4\arccos\left[\frac{4}{y}\right]+\sqrt{y^2-16}+C$$
Got a sign and arcsin vs arccos ?
Hint: Consider the following identity:
\(\displaystyle \arccos(u)+\arcsin(u)=\frac{\pi}{2}\)
$\tiny{206.8.4.31} \\
\text{Given (answer by maxima)}$
$$\displaystyle
$\text{identity }
\displaystyle\tan^2\theta = \sec^2\theta - 1 $
$$\displaystyle y=4\sec\left({\theta}\right)
$\text{substitute}$
$$\displaystyle
$$=\frac{-4
\right]}
$\text{back substitute }
\displaystyle \theta=\sec^{-1}\left(\frac{y}{4}\right)$
$$I_{31}=4\arcsin \left[\frac{4}{y}\right]+\sqrt{y^2-16}+C$$
That helped. 😎😎
karush said:
206.8.4.31
$$\displaystyle
trig subst
so
kinda ?
I would have made some manipulation to the integrand first to make the substitutions a little more obvious...
$\displaystyle \begin{align*} \int{ \frac{\sqrt{y^2 - 16}}{y}\,\mathrm{d}y} &= \int{ \frac{\left( \sqrt{y^2 - 16} \right) ^2}{y\,\sqrt{y^2 - 16}}\,\mathrm{d}y } \\ &= \int{ \frac{\left( \sqrt{y^2 - 16} \right) ^2 }{y^2} \left( \frac{y}{\sqrt{y^2 - 16}} \right) \,\mathrm{d}y } \end{align*}$
Now let $\displaystyle \begin{align*} u = \sqrt{y^2 - 16} \implies \mathrm{d}u = \frac{y}{\sqrt{y^2 - 16}}\,\mathrm{d}y \end{align*}$ and the integral becomes
$\displaystyle \begin{align*} \int{ \frac{\left( \sqrt{y^2 - 16} \right) ^2}{y^2}\left( \frac{y}{\sqrt{y^2 - 16}} \right)\,\mathrm{d}y } &= \int{ \frac{u^2}{u^2 + 16}\,\mathrm{d}u } \\ &= \int{ \left( 1 - \frac{16}{u^2 + 16} \right) \,\mathrm{d}u } \\ &= \int{1\,\mathrm{d}u} - \int{ \frac{16}{u^2 + 16}\,\mathrm{d}u } \end{align*}$
and I'm sure you can continue from here...
FAQ: How Is the Integral of sqrt(y^2-16)/y Solved Using Trigonometric Substitution?
1. What is the function of "206.8.4.31" in the equation?
The number "206.8.4.31" is not a part of the equation. It is most likely an IP address or some other identifier used for tracking purposes.
2. What does "int" stand for in the equation?
"int" stands for "integer" and it indicates that the result of the equation should be a whole number, rather than a decimal or fraction.
3. What does "sqrt" mean in the equation?
"sqrt" stands for "square root" and it is a mathematical function that calculates the square root of a given number.
4. What is the significance of "y" in the equation?
"y" is a variable that represents a number or value that can change. In this equation, it represents the input number for which we are trying to calculate the square root of (y^2-16)/y.
5. How do you solve this equation?
To solve this equation, you would first substitute a value for "y". Then, you would calculate the square root of (y^2-16)/y and make sure the result is a whole number. If it is not a whole number, you would try a different value for "y" until you find one that gives a whole number result.
