How is the Laplacian expressed in spherical coordinates?
  • MHB
  • Thread starter Chris L T521
In summary, the Laplacian operator is a mathematical tool used to describe the variation of a quantity in three-dimensional space. It is represented by the symbol ∇² and is defined as the sum of the second derivatives of a function with respect to each coordinate. In spherical coordinates, the Laplacian is expressed as (1/r²) ∂/∂r (r² ∂/∂r) + (1/r² sin θ) ∂/∂θ (sin θ ∂/∂θ) + (1/r² sin² θ) ∂²/∂φ². Its physical significance lies in describing the rate of change of a physical quantity with respect to its position
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: Let $u:\mathbb{R}^3\rightarrow \mathbb{R}$, and define the Laplacian $\nabla^2u$ in rectangular coordinates $(x,y,z)$ by
\[\nabla^2u=\frac{\partial^2u}{\partial x^2} + \frac{\partial^2u}{\partial y^2} + \frac{\partial^2u}{\partial z^2}.\]
Show that the Laplacian $\nabla^2u$ in spherical coordinates $(\rho,\phi,\theta)$ is given by
\[\nabla^2u=\frac{\partial^2u}{\partial\rho^2} + \frac{2}{\rho}\frac{\partial u}{\partial\rho} + \frac{1}{\rho^2}\frac{\partial^2u}{\partial\phi^2} + \frac{\cot\phi}{\rho^2}\frac{\partial u}{\partial\phi} + \frac{1}{\rho^2\sin^2\phi} \frac{\partial^2u}{\partial \theta^2}\]
Suggestion:
It may be a good idea to convert from rectangular to cylindrical coordinates $(r,\theta,z)$ first, where the Laplacian is
\[\nabla^2u=\frac{\partial^2u}{\partial r^2} + \frac{1}{r}\frac{\partial u}{\partial r} + \frac{1}{r^2}\frac{\partial^2u}{\partial\theta^2} + \frac{\partial^2u}{\partial z^2}\]
and then convert from cylindrical to spherical.
This week's question was answered by Sudharaka. You can find his answer below.
The gradient of a scalar field in spherical coordinates \((\rho,\,\phi,\,\theta)\) is given by,\[\nabla u(\rho, \phi, \theta) = \frac{\partial u}{\partial \rho}\mathbf{e}_\rho+\frac{1}{\rho}\frac{\partial u}{\partial \phi}\mathbf{e}_\phi+\frac{1}{\rho \sin\phi}\frac{\partial u}{\partial \theta}\mathbf{e}_\theta\]
The Laplacian is the divergence of the gradient. So we get,
\begin{eqnarray}
\nabla^2u &=& \operatorname{div}\left(\frac{\partial u}{\partial \rho}\mathbf{e}_\rho+\frac{1}{\rho}\frac{\partial u}{\partial \phi}\mathbf{e}_\phi+\frac{1}{\rho \sin\phi}\frac{\partial u}{\partial \theta}\mathbf{e}_\theta\right)\\
&=& \frac1{\rho^2} \frac{\partial}{\partial \rho}\left(\rho^2 \frac{\partial u}{\partial \rho}\right) + \frac1{\rho\sin\phi} \frac{\partial}{\partial \phi} \left(\frac{\sin\phi}{\rho}\frac{\partial u}{\partial \phi}\right) + \frac1{\rho\sin\phi} \frac{\partial}{\partial \theta}\left(\frac{1}{\rho \sin\phi}\frac{\partial u}{\partial \theta}\right)
\end{eqnarray}
Simplification yields,
In the next couple days, I'll edit this post to include a step by step justification of the identity from rectangular coordinates.
FAQ: How is the Laplacian expressed in spherical coordinates?
1. What is the Laplacian operator in spherical coordinates?
The Laplacian operator in spherical coordinates is a mathematical tool used in physics and engineering to describe the variation of a quantity in three-dimensional space. It is represented by the symbol ∇² and is defined as the sum of the second derivatives of a function with respect to each coordinate.
2. How is the Laplacian expressed in spherical coordinates?
In spherical coordinates, the Laplacian operator is expressed as:
∇² = (1/r²) ∂/∂r (r² ∂/∂r) + (1/r² sin θ) ∂/∂θ (sin θ ∂/∂θ) + (1/r² sin² θ) ∂²/∂φ²
Where r, θ and φ are the radial, polar and azimuthal coordinates, respectively.
3. What is the physical significance of the Laplacian in spherical coordinates?
The Laplacian in spherical coordinates is used to describe the rate of change of a physical quantity with respect to its position in three-dimensional space. It is commonly used in fields such as electromagnetism, fluid dynamics and quantum mechanics to model the behavior of physical systems.
4. How is the Laplacian used in solving differential equations?
The Laplacian is used in solving differential equations by allowing us to express the second derivatives of a function in terms of its first derivatives. This simplifies the equations and makes them easier to solve. In particular, the Laplacian is often used in solving the Schrödinger equation in quantum mechanics and the Navier-Stokes equation in fluid dynamics.
5. What is the Laplace equation and how is it related to the Laplacian in spherical coordinates?
The Laplace equation is a special case of the Laplacian, where the function being considered is harmonic (i.e. it satisfies Laplace's equation). In spherical coordinates, the Laplace equation takes the form:
(1/r²) ∂/∂r (r² ∂ψ/∂r) + (1/r² sin θ) ∂/∂θ (sin θ ∂ψ/∂θ) + (1/r² sin² θ) ∂²ψ/∂φ² = 0
This equation is commonly used in electrostatics and heat transfer problems, where the solution ψ represents the electric potential or temperature distribution, respectively.
