- #36
harrylin
- 3,875
- 93
hprog said:OK thanks all of you for your effort, but I do not understand your answers.
Forget a moment about the relativity of simultaneity, if fire spreads out in two directions with every thing being equal is there any reason for the fire going in one side faster than the other, or the ball flying in one direction faster than the other? this is physics and we need to have an answer and rule why this should happen.
Here is another such experiment, suppose we have a pool and we pure water directly in the middle of the pool and the water is spreading out to both sides, is there a reason why the water should arrive to one end of the pool before the other? farther more if the pool is an exact rectangle the water will arrive to the left and right sides (perpendicular to the direction of motion) simultaneously so why is this not happening in the direction of motion (and the same can be said for the ball and fire in which going sideways will yield simultaneous results).
You already received a number of replies, but perhaps the following qualitative explanation may help.
"every thing being equal" implies that you deem the forest or house that is burning to be in rest. For a forest in rest (homogeneous and without wind), we expect the fire to go at the same speed in both directions.
Now the new thing with SR is that for a forest (or water waves) in motion, this is not the case. For example, if you use a reference system in which the forest (or swimming pool) is going at almost the speed of light, the fire will not in one direction go faster than the speed of light; that would be against the laws of physics.
Thus we predict that as measured in such a reference system, the fire will propagate less fast in the same direction as the forest than in the opposite direction. The transformation equation with which you can calculate this has already been mentioned.
Harald
