How is the square of a transformed vector not a vector?
In summary, the conversation discusses the concept of vectors and their transformation between different coordinate systems. The components of the resulting vector are squared, but this result is not itself a vector. The proof for this is shown by the fact that each component does not transform in the same way in the original coordinates. The definition of a vector is also discussed, with emphasis on its independence from the choice of coordinate system. It is mentioned that this definition allows for a physical entity to be represented, even without specifying a coordinate system. The term "contravariant" is also explained in relation to the vector transformation law. The conversation also raises the question of whether or not this concept is tensorial.
BHL 20
66
So I learned that if a vector (a1, a2, a3) is transformed to a different set of coordinates, and the components of the resulting vector are squared like so: (a1'2, a2'2, a3'2), this result is not itself a vector. The proof for this simply shows that each component ai'2 does not transform to ai2 when brought to the original coordinates.
I'm having a lot of trouble understanding this. Say the vector (1,0,0) is transformed by a 90O rotation about the z-axis. It becomes (0,-1,0). The "square" of this is (0,1,0). Sure this doesn't transform back to (1,0,0) but if this triplet is considered in isolation, without any reference to the original vector, there doesn't seem to be any reason not to consider it a vector.
(a1'2, a2'2, a3'2) is of course a vector. It is simply not a result of a linear transformation of (a1', a2', a3')
It is correct to say that the map [itex]f: (a_0,\ldots,a_n)\rightarrow(a'_0,\ldots,a'_n)[/itex] maps vectors to vectors. The author's point appears to be that, given a linear map [itex]S[/itex], [itex]S f S^{-1}\neq f[/itex] in general. This is true precisely when [itex]f[/itex] is non-injective.
Where did you learn this? It may be that there is some context missing here.
Or maybe you mean that somehow the transformation is not tensorial in some sense?
It's from a vectors and tensors course. It was an example used to illustrate the definition of a vector.
And, what, exactly, is the definition of "vector"? It is NOT simply "three numbers"! The same vector
in different coordinate systems may have different "components". In order to be a vector, there must be a specific homogeneous relation between the components in one coordinate system and the components in another.
(The point of "homogeneous" is that a vector that has all components 0 in one coordinate system has all components 0 in any
coordinate system (the "0 vector"). From that, it follows that if U= V in one coordinate system, then U- V= 0 in that coordinate system so U- V= 0 in any coordinate system so U= V in any coordinate system. The result of that is that if an equation involving only vectors (and their extension, tensors) is true in one coordinate system, then it is true in any coordinate system.)
Likes DrClaude
When books like this use the term "vector", they're not referring to an element of a vector space, or even a triple of numbers. They're referring to a function that associates a triple of real numbers with each ordered basis for ##\mathbb R^3## that can be obtained by applying some rotation R to the components of the standard ordered basis.
The authors never say that for some reason. I don't know if they think it's so obvious that it's not worth mentioning, or if they just don't have a clue what they're doing.
The function is such that the relationship between two triples associated with two different ordered bases is given by the tensor transformation law.
Suppose that the relationship between new (=primed) and old (=unprimed) basis vectors is given by
$$e_i' =Re_i = (Re_i)_j e_j =R_{ji} e_j.$$ Let x be a triple associated with the "unprimed" ordered basis, and let x' be the corresponding triple associated with the "primed" ordered basis. We have
$$x_j e_j =x_ie_i =x_i'e_i' =x_i' R_{ji} e_j$$ Since a basis is linearly independent, this implies that
$$x_j= R_{ji}x_i' = (Rx)'_j$$ and therefore
$$x=Rx'$$ and
$$x'=R^{-1}x.$$ The term "contravariant" is used because of the appearence of ##R^{-1}## instead of ##R## in this equation.
The claim in post #1 is saying that we shouldn't expect ##(x_i')^2=R_{ji} (x_j)^2## to hold just because ##x_i'=R_{ji}x_j## holds.
Likes HallsofIvy
In the context of tensors, the term "vector" usually does not just refer to a mathematical triple (x, y, z) of numbers. A "vector" must be defined in such a way that it converts to other coordinate systems in the correct way. That definition of "vector" makes it an entity that is independent of the choice of coordinate systems. (It is an equivalence class of triples with their associated coordinate system). That allows it to represent a physical entity that exists even if no one is around to specify a coordinate system to measure it in. Your (a1'2, a2'2, a3'2) will not undergo coordinate system transformations correctly. .
Related to How is the square of a transformed vector not a vector?
1. How can a square of a transformed vector not be a vector?
It is important to remember that a vector is a quantity with both magnitude and direction. When we square a transformed vector, we are essentially multiplying it by itself. This results in a new quantity with a different magnitude and direction, which may not necessarily be considered a vector anymore.
2. Can you explain the concept of a transformed vector?
A transformed vector is a vector that has been subjected to mathematical operations, such as rotation, scaling, or reflection. These operations change the original vector's magnitude and direction, resulting in a new vector with different properties.
3. Why is the square of a transformed vector important in science?
The square of a transformed vector is important in science because it helps us understand the relationships between different quantities in a system. It allows us to study and analyze changes in magnitude and direction, which can provide valuable insights into physical phenomena and processes.
4. How does the square of a transformed vector relate to vector algebra?
In vector algebra, squaring a transformed vector is equivalent to multiplying it by its transpose. This operation is useful in solving systems of linear equations and in calculating properties such as distance and angles between vectors.
5. Can you give an example of how the square of a transformed vector is not a vector?
One example is when we transform a vector by rotating it 90 degrees counterclockwise. The resulting vector will have the same magnitude as the original but a different direction. However, when we square this transformed vector, the magnitude remains the same, but the direction becomes 180 degrees from the original vector, making it a different quantity altogether.
  • Linear and Abstract Algebra
  • Quantum Physics
