How is the Volume of a Solid of Revolution Derived?
In summary, the formula for the volume of a solid formed by revolving a function $f(x)$ around the $x$-axis on the segment $x \in [a, b]$ is $V = \pi\int_a^b f^2(x)dx$. This formula can be used to prove that the volume of a sphere with radius $R$ is $V = \frac{4}{3}\pi R^3$ by considering the sphere as a composition of disks with thickness $dx$ and finding the formula for the volume of each disk.
Guest2
193
Consider the solid in three dimensions that is formed when the graph of a function $f(x)$, with $f(x) \ge  0$ for all $x \in [a, b]$, is revolved around the $x$-axis on the segment $x \in [a, b]$. Derive the following formula for the volume $V$ of this solid: $V = \pi\int_a^b f^2(x)dx$. Use the formula to establish that the volume of a sphere with radius $R$ equals $V = \frac{4}{3}\pi R^3$.
I don't know how to start this.
In order to obtain a sphere by revolving a function about the $x$-axis, we need to revolve a semi-circle. Now, a circle having radius $R$, and centered at the origin is:
\(\displaystyle x^2+y^2=R^2\)
If we solve this for $y=f(x)\ge0$ we obtain:
\(\displaystyle f(x)=\sqrt{R^2-x^2}\implies f^2(x)=R^2-x^2\) where $-R\le x\le R$. Because $f^2$ is an even function, and the limits are symmetrical about the $y$-axis, we may use the even function rule to then state:
\(\displaystyle V=2\int_0^R R^2-x^2\,dx\)
Now all that is left is to carry out the integration. :)
Thank you.
How do I prove the first part of the question? Deriving the formula: [tex]\displaystyle V = \pi\int_a^b f^2(x)\;{dx}[/tex]
Guest said:
Thank you.
Think of the sphere as being composed of a bunch of disks, having thickness $dx$. What would then be the radius of an arbitrary disk, and hence its volume $dV$?
FAQ: How is the Volume of a Solid of Revolution Derived?
What is the definition of volume of a solid of revolution?
The volume of a solid of revolution is the amount of space occupied by a three-dimensional object created by rotating a two-dimensional shape around an axis. This is commonly used in calculus to find the volume of objects such as cylinders, cones, and spheres.
How do you find the volume of a solid of revolution?
To find the volume of a solid of revolution, you can use the method of cylindrical shells, disk method, or washer method. Each method involves integrating a function that represents the cross-sectional area of the rotated shape with respect to the axis of rotation.
What is the difference between the disk method and the washer method?
The disk method is used to find the volume of a solid of revolution when the cross-sections are circles, while the washer method is used when the cross-sections are annuli (rings). The washer method involves subtracting the smaller circle's volume from the larger one's volume to account for the hollow space in the middle.
Can the volume of a solid of revolution be negative?
No, the volume of a solid of revolution cannot be negative. It represents the physical space occupied by the object, so it must always be a positive value. If the calculated volume is negative, it is likely due to a mathematical error or incorrect setup of the integral.
What are some real-world applications of finding the volume of a solid of revolution?
The volume of a solid of revolution has many real-world applications, such as finding the volume of a water tank, determining the amount of material needed to create a cylindrical container, and calculating the volume of a wine bottle or soda can. It is also used in physics to calculate the moment of inertia of rotating objects.
