How is this a telescoping series?
arhzz
Finding the limit of the series
Telescoping series formula
Hello !
Consider this series;
$$ \sum_{k=1}^{\infty} \frac{1}{(2k-1)(2k+1)} $$ It is said to find the limit of the series when approaches infinity.Now it is said that this is a telescopic series and that the limit is ##\frac{1}{2}## but I don't see it. I've split the an part (I don't know how to call it in english but it is the term within the sum symbol) I did that like this.
$$ \frac{1}{(2k-1)}+ \frac{1}{(2k+1)} $$ Now if we input k to let's say 3 we get this
$$ \frac{1}{2} + \frac{1}{3} +\frac{1}{3} + \frac{1}{5} +\frac{1}{7} + \frac{1}{7} $$. I think its fair to assume that only 1/2 should remain and the others should cancel out,that is kind of the thing by the telescoping series.But I have + across the board and the fractions won't cancel out but rather add up.I am not sure how the - is supposed to come into play here,since as I've been taught yestarteday we have to sum up the elements.The only logical solution would be that within the parantheses one element has to be negative,but I don't see how we get to that.
Are you sure about that?
Likes FactChecker
Why do you think
$$ \frac{1}{(2k-1)(2k+1)} = \frac{1}{(2k-1)}+ \frac{1}{(2k+1)} $$ ?
Plug in a value for k. Like 2.
Likes FactChecker
Vanadium 50 said:
Why do you think
Okay so you are definately right,these are not the same so the algebra doesn't add up.I supposed it would have to be 1st fraction - 2nd fraction but I assumed it would be + because I don't know intuition? I saw * in the denominator and simply assumed it would be +
Don't use intuition. Use algebra.
Yea I guess I rushed it. It all makes sense now,thanks for pointing out the mistake.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
