How is this sound generated? / reverse engineer sound
In summary: The Pulse Width Modulation (PWM) allows the frequency of the wave to be varied.2) Sawtooth waves have a range of frequencies, so it can be whatever you like.3) Yes, I am aware of a free program that can do this.4) I would recommend trying a 10 band EQ to adjust the sound to your liking.
btb4198
572
Sounds like bells. Say tubular bells struck by rubber hammers?
Of course - technically - the sound is generated by a bunch of electronics responding to digital input.
What do you mean by "reverse engineer"?
There are a lot of things that can make the same or very similar sounds, so working out what did it is a matter of guesswork based on context. In the context of the website - someone fiddled with some sliders on the UI perhaps?
There are several components to this. To recreate it try the following:
Make a repeating sequence of a couple of dozen notes playing simple arpeggios at about 180 notes a minute.
1) Generate the basic tone by mixing a sawtooth wave with a PWM wave where the pulse width is set to vary slowly (about 2 LFO cycles per minute) between 25% and 50% duty cycle. Send this signal through a low pass filter with a cutoff of about 500 Hz and very little resonance. Set the amplitude envelope to have a slowish attack and release, with high sustain and a decay of abut the same as the attack (but the sustain is high so this doesn't make much of a difference). Set the envelope rate to scale with the keyboard to make the envelope faster for higher pitched sounds and slower for lower pitched sounds to give high frequency "tinkles" and lower frequency "whoops". Modulate the filter cutoff a little with the envelope.
2) Add a very little (very little) amount of very slow phase shift.
3) Add some reverb and maybe a little delay of about 350 ms.
4) Pass this through a 10 band EQ.
Tinker with it until it sounds like the sound on that page.
Reverse engineering is when you go backward. In this case from the sound.
Pretty sure Simon knows the definition. We are asking what you mean by it in this context.
The music is almost certainly (i.e. approaching 1.0) electronically generated, so there's nothing to reverse engineer it to.
What you'd do it analyze the waveform and look at the envelope (attack, sustain, decay, release). Reproducing that would get you the sound.
http://en.wikipedia.org/wiki/Synthesizer#ADSR_envelope
Likes dlgoff
what is (i.e. approaching 1.0) electronically generated?
ok a few questions:
about your number 1:
1) what do you mean buy PWM wave where the pulse width is set to vary slowly (about 2 LFO cycles per minute) between 25% and 50% duty cycle?
can you please explain?
2) what frequency should the sawtooth wave be?
also do you know a good program that can do all of this ?
Sorry. That was cryptic.
I was simply saying the probability that the sound was electronically-generated is pretty much certain.
You asking if if can be reverse-engineered. I'm thinking you want to know what instruments made it? No physical instrument made the sound, it was made by a piece of software. So I'm not sure what you expect to get from it.
What you can do is analyze the waveform. Envelope will tell you about the sound of each note (this is on the order of seconds). Timbre (tome) is a property of wave shape - each cycle of an individual cycle (this is on the order of milliseconds).
Related to How is this sound generated? / reverse engineer sound
1. How do vibrations create sound?
Sound is generated when an object vibrates, creating changes in air pressure. These changes travel through the air as sound waves and are interpreted by the ear as sound.
2. How do different materials affect the sound produced?
The type of material an object is made of can greatly influence the sound it produces. For example, a metal object will create a different sound than a wooden object due to differences in their density and elasticity.
3. How does the shape of an object affect the sound it produces?
The shape of an object can also impact the sound it creates. A hollow object, like a drum, will produce a different sound than a solid object of the same material due to the resonance and amplification of sound within the hollow space.
4. How can sound be reversed engineered?
Sound can be reverse engineered by analyzing the different components that make up the sound, such as pitch, frequency, and amplitude. By understanding how these elements work together, scientists can recreate and manipulate sound.
5. How does the human ear interpret sound?
The human ear interprets sound through the vibrations of the eardrum, which then travel to the inner ear and are converted into electrical signals that are sent to the brain. The brain then interprets these signals as sound, allowing us to hear and understand the world around us.
  • Electrical Engineering
  • Computing and Technology
