How Is Total Mass Calculated in General Relativity for a Finite Body?
In summary: But you don't really need to know all that. One measure of the mass-energy of a body is the Kretschmann scalar, which is a measure of the curvature at a point. You can compute it from the metric. If you know the Kretschmann scalar, you know the density of mass-energy at that point. To get the total mass-energy of the body, you need to know the volume. You can get that by knowing the area of the horizon, and the distance the horizon is from the center of mass. That'll give you the "mass-energy" of the body.There is no "unique" answer. You can use different measurements to get different numbers. All
  • #36
blue_sky said:
I'am startint to think thaf in full GR the integral over a finite volume don't have any phisical meaning; what is describing the full GR world are only the local equations.
So in full GR is a non sense to define the mass of a body with finite dimentions.
Any of you support this?
Not I.
In GR you need to have invariant particle (rest) mass in order to make measurements of mass, length and time.
Sorry Garth but that makes no sense to me.
I know that in SR that's not true at all. E.g. If a charged particle of known charge, q, is moving in a uniform magnetic field (of known strength B) in a plane which is perpendicular to the B-field then the particle will move in a circle. The speed, v, can be measured from observing the position as a function of time. This then determines gamma. The radius, R, of the circle is also measurable quantity. Then measurement of q, B and R thus gives you a measurement of momentum since p = qBr. Since p = mv = gamma*m0 and since you know p and v you then know m = p/v and this m is not an invariant quantity.
Pete
  • #37
pervect said:
It sounds like you've read the sci.physics.faq on energy in GR :-) Of course there are some important special cases where this issue can be resolved.
Nope, but if you can tell me where to look, I would appreciate.
blue
  • #38
Whether or not you would like to define something in GR with the name "mass," it is not in any way required. GR cares about the stress-energy tensor, and only the stress-energy tensor. And that is certainly a measurable object.
The situation is complicated a bit by singularities, which may be called a form of "topological mass," but then you just specify the metric (almost) everywhere, and you've described your spacetime. Since knowing the metric implies knowing the stress-energy tensor, you can also do this with matter. Of course that's not very pretty, but there are no issues of principle.
  • #39
Garth said:
What I think is that it is GR that needs to be modified, but that is a personal (and how!) opinion!
There are two issues here for GR, or any physical theory, the first is how to apply the theory's equations consistently, the question you raise above, i.e. 'doing the mathematics', and the second is how to relate the terms and definitions in those equations to physical objects and measurements. In order to have any correlation between the GR theory world and the real world the theory demands that particle (rest) masses have to be invariant, otherwise we would be in an 'Alice Through The Looking Glass' world in which the mathematical terms used would lose, or at least change, their meaning.
If we now consider an extended gravitating body with particle number conservation then in GR the total rest mass of all those particles has to be constant. The question is then how to add on the mass equivalent of all the energy fields present, especially the binding energy of the gravitational field itself. It is here that the going gets tough!
- Garth
I agree with the exception of the total mass rest. Why we do need a total mass rest? This looks like a concept we are "importing" from classical phisycs. The question is: we do need it?
blue
  • #40
I tend to agree. Any 1 as a different view?
blue
  • #41
"In GR you need to have invariant particle (rest) mass in order to make measurements of mass, length and time. "
I was referring to remote observations, i.e. extending a metric using units defined here in a laboratory out to the far reaches of the universe.
Weyl’s hypothesis (Weyl, H.: 1918, ‘Gravitation und Electriticitat’ Sitzungsberichte der Preussichen Akad. d. Wissenschaften, English translation, 1923, in: The Principle of Relativity, Dover Publications.) was that a true infinitesimal geometry should recognize only a principle for transferring the magnitude of a vector to an infinitesimally close point, and not throughout the space-time manifold as in GR.
This led to the concept that the space-time manifold M is equipped with a class [gµν] of conformally equivalent Lorentz metrics gµν and not a unique metric as in GR. Conformal gravity theories use this insight in conformal transformations, in which one metric transforms into a physically equivalent alternative.
The problem with these theories is the mass of a particle varies with the transformation, together with units of length and time. It is a measurement problem, how do we know the terms in our equations concerning a distant object (mass, length, time) are the same as for a similar object in the laboratory? The adoption of the conservation of energy-momentum in GR provides a solution. Define mass to be constant and rulers will be fixed and clocks regular, we then interpret red shift as recession, the universe is expanding but have to invoke inflation, dark matter and dark energy to make it work.
Perhaps it is otherwise?
