How Is Work Calculated on a Conveyor Belt with Friction?
In summary, the work done on a conveyor belt with friction is calculated by considering both the force exerted to move the load and the frictional force opposing the motion. The total work is the product of the total force applied (including the force to overcome friction) and the distance the load is moved. The frictional force is determined by the coefficient of friction and the normal force acting on the conveyor belt. Therefore, to accurately calculate work, one must account for both the useful work done in moving the load and the energy lost due to friction.
  • #36
erobz said:
I just didn’t want you to be confused about this later on.
ok thank you soo much! ill keep that in mind
can you also help me with the other options?
for a
work is done because it gains GPE
for c, it gains GPE too
for d it looses gpe and gains KE
  • #37
hello478 said:
that energy = work?
but first tell me if this is correct...
work done is 0 because there is no net force...?
also if there is no net force how can the box move??
@erobz Answered them clearly.
Likes hello478
  • #38
for a
You gotta try to apply the definition we just explained to each case…and tell us what you get. Did you apply the definition or just wing it to get those results…
Likes hello478
  • #39
for a
For a particle total work is related to change in KE. Not PE.
  • Skeptical
Likes haruspex and BvU
  • #40
will get back to you in a while 😶
(might take a few hours)
Likes erobz
  • #41
but isnt PE also energy?
and so energy = work?
Likes BvU
  • #42
Read option a again. Think of work and energy theorem. Do you think work done on the object is nonezero?
  • Skeptical
Likes BvU
  • #43
will do and let you know... :)
  • #44
hello478 said:
will do an let you know... :)
Are you working out of a textbook?
  • #45
Work tells you how much energy changes:$$\Delta E = F_\text{net} \times D$$where ##D## is the distance moved in the direction of the net force.
You can count gravitational potential energy on the energy side. But then you need to remove gravity from consideration on the force side:$$\Delta (\text{GPE} + \text{KE}) = F_\text{non-g} \times D$$
Or you can treat gravity as just another force. In this case you need to remove gravitational potential energy from the energy side:$$\Delta \text{KE} = F_\text{net} \times D$$
In my opinion, this problem assumes the latter approach. We are treating gravity as just another force. A force that can contribute to the net work done.
  • #46
MatinSAR said:
Read option an again. Think of work and energy theorem. Do you think work done on the object is nonezero?
There is a fundamental problem with “A” because it is a frictionless belt…probably best just skip it for the time?
Likes MatinSAR and hello478
  • #47
yeah we can address it later on
  • #48
no, using google and the previous explanations you and everyone gave...
but as im working on many questions simultaneously so it will take me a few hours to figure out the answer and reply
  • #49
The problem says no "resistive" forces. A forward force from the conveyor belt is not resisting the motion. It is assisting it.
  • #50
Well it was pointed out early ( by @kuruman , and maybe @haruspex) that at the very least the wording is unclear. On the incline it can be argued that as it climbs the ramp friction must be there to resist the boxes component of weight down the ramp.
I don’t think this is the intention, but it seems like a point of contention. We should probably abandon it for the sake of the OP and say they didn’t mean frictionless belt.
Likes MatinSAR
  • #51
hello478 said:
for a work is done because it gains GPE
Read post #6 again.
In a, work mgh is done by the belt and work -mgh is done by gravity. But the question asks about work done on the case: mgh+(-mgh)=0.
Likes MatinSAR
  • #52
and, indeed, did not say frictionless belt. They wrote no "resistive forces opposing motion", which is ambiguous. The motion could mean the actual velocity of the case up the ramp (the friction does not oppose that) or it could be taken as the motion that would occur were there no friction: acceleration down the ramp.
  • #53
I agree, but I think they meant there is friction between the belt and the box, and there is no “drag” type forces.
  • #54
Oh yes, that is what was meant, no question.
Likes erobz
