How it works: television screen
In summary, the length of time over which a phosphor emits light is an important factor to consider when designing a television screen because it affects the flicker fusion frequency, which is the rate at which a human eye can perceive a continuous stream of light. This can impact the overall viewing experience for viewers.
HelloKitty_1
Why is the length of time over which a phosphor emits light an imporant factor to consider when designing a television screen?
I have gone over the last three chapters in my textbook for the answer. I even drove to the library to try to get some more understanding of it.
Welcome to the PF.
Hint -- use the search term "flicker fusion frequency".
Related to How it works: television screen
1. How does a television screen produce images?
A television screen produces images by using a series of pixels that are made up of three subpixels: red, green, and blue. These pixels are illuminated by an electron beam that scans across the screen, creating a pattern of light that forms an image.
2. What is the role of the cathode ray tube (CRT) in a television screen?
The cathode ray tube (CRT) is a vacuum tube that is used to generate and control the electron beam in a television screen. It works by heating a cathode, which releases electrons that are then accelerated towards a phosphor-coated screen, creating an image.
3. How does a flat-screen television differ from a CRT television?
A flat-screen television uses a different technology called liquid crystal display (LCD) or light-emitting diode (LED) to produce images. These screens do not use an electron beam, but instead, use liquid crystals or LED lights to create images.
4. How does a television screen display color?
A television screen displays color by using a combination of the three primary colors: red, green, and blue. These colors are mixed together in different intensities to create a wide range of colors that we see on the screen.
5. How is the image on a television screen refreshed?
The image on a television screen is refreshed by displaying multiple frames per second. This is known as the refresh rate and is typically 60 frames per second for most modern televisions. This creates the illusion of a continuous image instead of a series of still frames.
  • Science Fiction and Fantasy Media
