How large an area is that brightly illuminted patch from stars covering?
  • Thread starter james gander
  • Tags
    Area Stars
In summary: If the sun is at least 90 million miles away and illuminates earth, and stars are the same as our sun, then am i correct in assuming that each star we see in the sky is illuminating an area of at least 90million miles!??The stars vary greatly in size.The stars vary great in size.
james gander
If the sun is at least 90million miles away and illuminates earth, and stars are the same as our sun, then am i correct in assuming that each star we see in the sky is illuminating an area of at least 90million miles!??
We see a little white dot from this far away but, does that little dot on each star actually cover 90 million miles? Is that little area honestly that large and if not, then how large is the illuminated area?
Surely my assumption is wrong!
Thanks.
Astronomy news on Phys.org
Likes james gander
I know that they vary in size but my questions are:
Am i right in believing the illuminated area we see from the average star on Earth must cover at least 90million miles? (if the star is the size of our sun)
If the our sunlight reaches Earth and we are 90million miles away from our sun, then surely the little dots in the sky made from stars the size of our sun must be illuminating at least 90million miles in area. Thse little white dots are actually 90million miles across. If not how?
I don't get your connection between the earth-sun distance and the brightness of other stars. The photons emitted by a star start off with a given density per area. As the distance from the star increases, the density of photons falls off because they are spread over a larger area.
To put it another way, any star that you can see, is illuminating the Earth - just not very brightly.
The light from stars reaches us from the star but the width of the star covers an area of the sky about a millimter across when looking at it from the earth. I am not asking about brightness.
My question is, how large an area on average are little dots we see from Earth actually covering? Are those little pinpoints millions of miles across?
So how big on average is the are we see illuminated in the sky? i understand it is illuminating the Earth but it is aso illuminating a very bright area in the sky which from Earth looks like only a mm in diameter, but how large an area is the highly illuminated patch of space covering?
The 'area' that you're thinking of is affected by many things like the size of the star, it's distance from Earth and scattering of the light as it passes through the Earth's atmosphere. Take a look at the Wiki article on Angular diameter in Astronomy.
i just want a very approx number for an average star. Is it thousands of miles, millions or just hundreds?
The sun has a radius of 696,342±65 km which means its diameter is just under 1.7 million km. There are larger stars and there are smaller ones. If I remember correctly, most are smaller. Of course those are harder to see.
Could anyone please give me a very approximate answer. I am sure it is known by someone without me having to study the formulas for the angular diameter. Angular diameter is new to me, this is just a hobby to me i have not even purchased a telescope yet. Its the incomprehensible numbers of the universe i find amazing and this is a number i can't even get an approximation for.
How large is the area of space is brightly illuminated from an average star?
From Earth it looks to be about a mm, but how large do you think that bright area actually is? I am not asking how far starlight shines, as we all know it shines forever.
Still, that very bright area we see from Earth must have a size. So is it just a few hundred miles or is it thousands, millions or lightyears?
Sorry to ask but i am unsure if anyone understands what it is i am asking.
Thanks for you patientce.
I think the problem is that we are not sure that YOU understand what you are asking.
If a star has only very small planets then what we are seeing is just the star. We are not seeing anything millions of miles away from the star.
If a star were in the middle of a gas cloud 500 million miles in diameter, then what we are seeing is an illuminated area 500 million miles in diameter.
In other words, you are asking for a definitive answer to something that doesn't HAVE a definitive answer.
Likes james gander
Yes the sun is about 900,000 miles in diameter, so is it fair to say the area of a star that we seeon Earth must be much larger.
If the light reaches us from that star then the light must of traveled at least that far in all other directions too. We only see it as a pinpoint because the star is so far away but that still does not explain say how large that pinpoint actually is.
If the star is the size of our sun aprrox 900,000 miles then the pinpoint must be at least 900,00 miles across but that doesn't take into account the amount of area that has been illuminated areound the cirumfernce of that star.
Do we just see the actuall size of the star from Earth (900,000miles) and if so how come we don't see any light illuminating any other direction except straight towards us?
You just asked questions that I answered in the post right before yours.
Okay, now thanks this makes sense i need sleep!
What we see from Earth is just the stars diameter, the light comes towards us and hits my eyes, so the light has traveled millions of miles to earth. We don't see the light going in all the other directions for millions of miles because the light has nothing to reflect off of (unless there was a nearby object). IS this correct? Thanks by the way.
james gander said:
IS this correct?
Yes, it is correct. When we see stars its only their surface.
james gander said:
... so the light has traveled millions of miles to earth.
You are a master of understatement.
You're correct. You CANNOT determine the actual size of a star just by looking at how large it appears with the naked eye (or even with telescopes). The reason for this is that the angular diameter of the star is MUCH smaller than your eye (or even a telescope) can resolve.* The incoming light from the star is focused onto your retina, but diffraction spreads the light out into a 'spot', called an airy disk. The brighter the star, the larger the spot appears to be. (The spot doesn't actually change size, its just that the light at the outer areas of the spot becomes great enough for your eye to detect when you look at brighter stars) That's why bright stars appear larger when there's actually no connection between the stars real size and how big they appear when looking at them.
See the following links:
http://en.wikipedia.org/wiki/Angular_resolution
http://en.wikipedia.org/wiki/Airy_disk
*The only exceptions are a few very massive, very close stars, like Betelgeuse. The Hubble Space Telescope was actually able to resolve the star into a disk instead of just a pinpoint. The image of the star fit on just 10 pixels of the camera. See here: http://iopscience.iop.org/1538-4357/463/1/L29/pdf/5023.pdf
The latter parts are correct, but the part about seeing the diameter is not, as I explained just above. Also note that the nearest star is almost 4 light-years away. One light-year is is 5.8786×1012 miles, or 5.8 trillion miles. That puts the nearest star at over 20 trillion miles away, and most stars are hundreds or thousands of light-years from us.
Related to How large an area is that brightly illuminted patch from stars covering?
1. How is the size of the brightly illuminated patch from stars determined?
The size of the brightly illuminated patch from stars is determined by the distance of the stars from Earth and their brightness. The further away a star is, the smaller its illuminated patch will appear. Similarly, the brighter a star is, the larger its illuminated patch will appear.
2. Can the size of the brightly illuminated patch from stars change?
Yes, the size of the brightly illuminated patch from stars can change over time. This is because stars are constantly moving in space, so their distance from Earth and their brightness can change, thus affecting the size of their illuminated patch.
3. Is the size of the brightly illuminated patch from stars the same for all stars?
No, the size of the brightly illuminated patch from stars can vary greatly. This is because stars have different distances from Earth and different levels of brightness. Some stars may appear as a small point of light, while others may appear as large and bright objects.
4. How does the size of the brightly illuminated patch from stars compare to the size of the moon?
The size of the brightly illuminated patch from stars is significantly smaller than the size of the moon. The moon has a diameter of about 3,474 kilometers, while the size of the illuminated patch from stars can range from a few hundred kilometers to several million kilometers, depending on the distance and brightness of the stars.
5. Can the size of the brightly illuminated patch from stars be measured?
Yes, the size of the brightly illuminated patch from stars can be measured using astronomical tools and techniques, such as telescopes and photometry. Astronomers can calculate the size of the illuminated patch by measuring the distance and brightness of the stars within the patch.
21K
