How large is the volume of a photon interacting with matter?
In summary, the volume of a photon interacting with matter is not defined in conventional terms, as photons are massless particles that do not occupy space like classical objects. Instead, their interactions are described by quantum mechanics, where the concept of volume can be related to the effective cross-sectional area during scattering or absorption events. These interactions depend on factors such as wavelength, energy, and the characteristics of the material involved.
johaninumea
When a photon interacts with matter and diffracts, the photon seems to interact with the area of its wave front, determined by an aperture even if it is only one photon. But how far does it interact in depth? Does it always "feel" the whole crystal? Can we assume the photon is reflected by the whole crystal?
I'm sorry youtube has its claws in this link, but it's a good treatise
:welcome:
Separately shot single photons create interference patterns, so they travel as if they "knew" about whole structure they interact with.
Likes south
OK thanks!
The photon must be considered as interacting with everything everywhere because the concept of a photon having an extent does not fit current theory. Of course, in practical terms you only need to consider regions near to the position where the majority of light energy is constrained by conventional optics.
If you truncate the integral that's used in the diffraction calculation then an (sometimes very small) error results.
Likes Dale
Thank you, very well explained! Appreciate this.
I assume though it follows the energy goes with the wave front, so that if would diffract once and then the photon interacts with the crystal a second time, it does not see the whole crystals, is this right?
Perhaps it's worth watching the Richard Feynman lectures at University of Auckland
Richard Feynman explains about photons and electrons, including how Feynman diagrams are used (in lecture 3 but don't skip the first 2). An accessible explanation of Quantum Electrodynamics and particle physics (a few details that were uncertain then have been confirmed since). Each lecture is over an hour and then there are excerpts from the question and answer sessions. If you have to teach about Feynman diagrams this gives an excellent insight into how they are used.
UH? It 'sees the whole of the crystal - after all, it's everywhere.
OK thank you very much to get a better understanding
Johan
There were some papers where they showed that one could engineer a screen with, e.g. three slits, such that a wildly non-classical trajectory would make a detectable contribution to the path integral and hence to the detection results. IIRC, an S-shaped path that went through one slit, then doubled back through a second one and finally forwards through a third. Unfortunately I don't have a link.
IS this with classical wave theory and an actual experiment?
Sigh...
BvU said:
Sigh...
Give us a clue - seriously - or was it because PW is only a popular mag?
Trying this experiment with microwaves and a slit antenna (30λ spacing) could easily produce 'sidelobes' at -30dB due to currents induced along the plate. So how would they tell?
It's ten years old !
But mostly because I was already thinking about all the two-slit dimwits who will use this to happily troll behind. Bit gloomy I grant you.
Likes sophiecentaur
FAQ: How large is the volume of a photon interacting with matter?
What is the volume of a photon?
A photon does not have a well-defined volume in the classical sense because it is a quantum particle. Its properties are better described by its wavelength and energy rather than a physical volume.
How does a photon interact with matter?
A photon interacts with matter primarily through electromagnetic forces. It can be absorbed, emitted, or scattered by particles such as electrons. These interactions are described by quantum electrodynamics (QED).
Can the concept of volume be applied to photons in any way?
While photons do not have a physical volume, their interactions with matter can be described in terms of the cross-sectional area, which is related to the probability of interaction. This area is dependent on the photon's wavelength and the properties of the matter it interacts with.
How does the wavelength of a photon affect its interaction with matter?
The wavelength of a photon determines its energy and the type of interaction it can have with matter. For instance, longer wavelengths (like radio waves) interact differently compared to shorter wavelengths (like X-rays or gamma rays). Shorter wavelengths generally have higher energy and can penetrate matter more deeply.
Is there a way to measure the "effective volume" of a photon during an interaction?
Instead of measuring volume, scientists measure the cross-sectional area of the interaction, which represents the likelihood of a photon interacting with a particle. This cross-section can be calculated using principles from quantum mechanics and quantum electrodynamics.
