How large would the sun be if it were frozen?
In summary, the sun has a complex density profile and is already denser than liquid hydrogen. If all its hydrogen and helium were to turn to liquid, the sun's volume would decrease, but it is not possible in reality due to the immense energy required to compress the core. The sun's average density is 1410 kg/m3, while liquid hydrogen has a density of 70 kg/m3. The sun's core would have to reach a state of electron degeneracy, similar to a White Dwarf, to compress to a smaller size. The sun's density varies greatly from core to surface, and it is a common misconception that stars are mainly composed of light gases and plasma. In reality, the sun is a dense, complex
dennis_n
How much smaller would the sun be if all it's hydrogen and helium turned to liquid?
I can't figure out how to calculate this. But I thought it would be fun to visualize how much smaller in size a frozen sun would be compared to it's gas/plasma state.
Anyone?
Astronomy news on Phys.org
This should be pretty easy to compute. The Sun's mass composition can be readily found on the internet, as can the densities of liquid hydrogen and helium, which are the Sun's main components. Just take the masses of hydrogen and helium and compute the corresponding volume using the densities.
Likes unusually_wrong, PeroK and russ_watters
No, it isn´t.
Hydrogen and helium will be self-compressed by gravity.
White dwarf mass-radius relationships won´t help, either, because white dwarfs are carbon or heavier.
I thought that too, but then the gases change density from surface to core, so I thought a simple computation might not solve this.
snorkack said:
No, it isn´t.
But this was not the question as I read it. The question as I read it is just "if the hydrogen and helium were liquid of the typical densities, how much volume would it occupy". It is obviously not going to happen in reality.
You do not need the volume of the gases. You just need the mass.
The average density of the Sun is 1410 kg/m3
Liquid hydrogen has a density of only 70 kg/m3
Thus the Sun is already denser than liquid hydrogen would be.
If you were to remove the energy source that keeps the Sun from collapsing, it would compress until its core reaches a state of electron degeneracy. At this point you have the equivalent of a White Dwarf, and an object with a radius comparable to the Earth's.
Likes dennis_n and Imager
I never thought to search for average density. It was faulty logic to assume that an extremely compressed plasma core wouldn't increase the average density to more than that of a liquid or solid state. Might be the public misconception that stars are mainly bodies of "Gas" and "Plasma" and we conceive both of these as very light, only experiencing gas as the air around us and thinking of plasma as an even more expanded form of it. Thanks! I learned something new today.
Weird.
So a liquefied sun would be 2.7 times larger in diameter. (Using Janus's hydrogen density)
I tried to figure out how big droplet of liquid He can exist.
By my estimate, somewhat smaller than Pluto, unless extra heating is provided. On account of the extra heating from relic radiation, a Pluto sized drop of He can be liquid without other heating.
So, how is it that Jupiter has approximately the same density as the sun?
1300 kg/m^3 Jupiter
1410 kg/m^3 Sun​
Asking for a friend.
I learned, by going down your rabbit hole, that I know way too little about how things work, on not-even-a-cosmic scale.
Likes nikkkom
The sun has a larger variation in density. It's quite dense at the core and much less dense near the surface,
Likes OmCheeto
Here is a good article from NASA with a nice density vs radius graphs:
https://solarscience.msfc.nasa.gov/interior.shtml
Likes dennis_n and OmCheeto
Related to How large would the sun be if it were frozen?
1. How would the size of the frozen sun compare to its current size?
If the sun were to freeze, it would actually decrease in size. This is because the sun's volume is primarily made up of gas, which would condense and shrink as it freezes.
2. How would the frozen sun affect the Earth's orbit?
If the sun were to freeze, it would not have a significant impact on the Earth's orbit. This is because the sun's mass would remain the same, and therefore its gravitational pull on the Earth would not change.
3. Would the frozen sun still emit light and heat?
No, a frozen sun would not emit light or heat. It would essentially become a giant frozen ball of gas, with no nuclear fusion occurring to produce energy.
4. Could the sun realistically freeze?
The sun freezing is highly unlikely, as it is constantly producing heat and energy through nuclear fusion. It would require a massive decrease in temperature, which is not possible in the sun's current state.
5. How would the frozen sun impact other planets in our solar system?
The frozen sun would not have a significant impact on other planets in our solar system. Its gravitational pull and mass would remain the same, and it would continue to orbit the center of the solar system as normal.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
