How long an object takes to stop - using friction, momentum
In summary,A block of mass 100 grammes was stationary on the flat surface at 0. The force of 10 Newtons was applied on the block in the positive x direction during 3 seconds. Find at what x position the block will stop, if the coefficient of kinetic friction between the block and the surface is 0.2.
gelfand
40
A block of mass 100 grammes was stationary on the flat surface at ##x = 0##. At
time ##t = 0## a horizontal force of 10 Newtons was applied on the block in the
positive x direction during ##\Delta t = 3## seconds.
friction between the block and the surface is ##\mu_k = 0.2##.
##I = F \Delta t = m \Delta v = \Delta p## (where ##p## is used for momentum)
I have that
F = ma
Then
\frac{10}{0.1} = a
$$And I can presume (?) that acceleration is constant.Then from this I have
a = 100
So if I have ##a = 100## then I can use Impulse as ##I = F \Delta t## to find
F \Delta t = \Delta p
So
(0.1) (100) (3) = \Delta p = 30
$$So from ##\Delta p = 30## I have ##m(v_f - v_0) = 30## and as ##v_0 = 0## this is
##mv_f = 30## and ##v_f = \frac{30}{0.1} = 300##
This gives me the velocity as ##300## m/s at the point the force has been
removed.
From here I need to know how long it takes for the force of friction to slow the
object to a stop.
This means all of the energy from the point ##t = 3## is spent on friction.
So
\frac{1}{2} mv^2 = \text{work done against friction}
$$So here I have that work done is ##W = F \Delta x## so given ##\mu_k = 0.2##, the
mass of the object is ##0.1## then I would have the force of friction as
F_{friction} = mg \times \mu_k = 0.1 \times 9.81 \times 0.2 = 10.11
$$So then I have
\frac{1}{2} (0.1) v^2 = 10.11 \Delta x
And so
\frac{1}{2} (0.1) v^2 \times \frac{1}{10.11} = \Delta x
Using the velocity found from before this gives $$
\frac{1}{2} (0.1) (300)^2 \times \frac{1}{10.11} = \Delta x
So ##\Delta x \approx 445.103## meters.
I don't really have much of a handle on what to expect from an answer here.
I think what I've done is reasonable though?
Thanks
gelfand said:
I have that
F=ma​
F = ma
Then
100.1=a​
\frac{10}{0.1} = aAnd I can presume (?) that acceleration is constant.Then from this I have
a=100​
a = 100
You need units here. Otherwise, that looks right.
gelfand said:
This gives me the velocity as 300300 m/s at the point the force has been
removed.
Yes, but it would have been much easier just to multiply the acceleration by ##3## seconds!
gelfand said:
So here I have that work done is W=FΔxW = F \Delta x so given μk=0.2\mu_k = 0.2, the
mass of the object is 0.10.1 then I would have the force of friction as
Ffriction=mg×μk=0.1×9.81×0.2=10.11​
You should be able to see without a calculator that multiplying ##9.81## by two small fractions is not going to give you something bigger.
Finally, you also need to think about how far the block moves during the acceleration phase.
Ah yes >.< , whoops.
So that the force of friction would be ##0.1 \times 9.81 \times 0.2 = 0.1962##.
The means that during the acceleration phase (from ##t = 0 ## to 3) I have the net
Force would be
F_n = 10 - 0.1962 = 9.8038
Given this I have the work done against friction over the three seconds as
F_n \times \Delta x
But I'm not sure how to find ##\Delta x## from this?
Can I use the conservation of energy here?
From that I would have that ##E = U + K + constant##. But I don't really have any
potential energy, and the kinetic energy at the start is zero (so this seems
like a poor choice).
Oh - I can just use the equations of motion here then, so I would have
x = x_0 + v_0 t + \frac{1}{2} a t^2
So here this is just ##x = 0.5 \times 100 \times 9 = 450##. So that I would have
moved ##350## meters during ##\Delta t## as a result of the force.
But is that correct? Do these equations work when there's friction present?
gelfand said:
So that the force of friction would be 0.1×9.81×0.2=0.19620.1 \times 9.81 \times 0.2 = 0.1962.
Yes, of course, you have friction during the acceleration phase as well.
x=x0+v0t+12at2​
So here this is just x=0.5×100×9=450x = 0.5 \times 100 \times 9 = 450. So that I would have
moved 350350 meters during Δt\Delta t as a result of the force.
I think it may be simpler to use equations of motion. There's no reason these won't work with friction, as long as you include the friction force when you calculate acceleration.
What you know is:
1) A force (10N - friction) acts for 3 seconds. The block accelerates, reaches a speed ##v##, and travels a distance ##d_1##, say.
2) Friction slows the block from the speed ##v##. The block travels a further distance ##d_2## until it stops.
You should be able to calculate the two distances from the equations of motion.
So I have ##a = 100, v = 300## after three seconds.
Then I remove the force that's pushing the object and friction slows it to a stop.
Then at three seconds I have the kinetic energy
\frac{1}{2} m v^2
And this is all spent on work against friction (so that the object comes to a
stop ), giving
F \Delta x = \frac{1}{2} m v^2
So I have ##F = m g \mu_k## then
\Delta x = \frac{\frac{1}{2} v^2 }{g \mu_k}
Which is
\Delta x = \frac{0.5 \times 300^2}{9.81 \times 0.2} \approx 22.935
So that I travel around 22.8 km it seems! (really? )
Is this right? The approach etc.
Thanks
gelfand said:
So I have a=100,v=300a = 100, v = 300 after three seconds.
You're forgetting that the friction force is acting during the acceleration.
gelfand said:
Which is
Δx=0.5×30029.81×0.2≈22.935​
Is that ##22.9m##?
gelfand said:
Which is
I did a quick calculation using ##g = 10ms^{-2}## and got exactly ##1.8 km##. That includes the distance accelerating and decelerating.
Sorry - that answer is correct but Its in thousands. I'd be unlikely to trust
any boss who gave me a job anyway tbh :)I thought that I had accounted for the frictional force during that, damn.
OK
\text{Force net} = 10 - mg\mu_k
Then we have that
F_n = ma
So
a = \frac{F_n}{m}
From this we can use impulse as
I = F \Delta t = (10 - mg \mu_k) \times \Delta t = \Delta p
So rearranging to solve for ##v_f## , where ##v_f## is the velocity at ##t = 3##
seconds gives
\frac{
m
} = v_f
We can use this value of ##v_f## to find the kinetic energy at ##t = 3## seconds
E = \frac{1}{2} m v_f^2
$$We know that all this energy is spent on work to bring the object to a stop.
Work ## = F \times \Delta x##, where ##F = mg \mu_k## so we have
\Delta x \times mg\mu_k = \frac{1}{2} m v_f^2
Dividing by ##mg \mu_k## gives
\Delta x = \frac{\frac{1}{2} m v_f^2}{mg \mu_k}
So we have to plug values here, velocity at 3 seconds is
v_f = \frac{10 - 0.1 \times 9.81 \times 3}{0.1} = 294.114
We have that the kinetic energy is equal to the work done which is ##F\Delta x##,
where here ##F## is just due to friction and is ##F = mg \mu_k = 0.1 \times 9.81
\times 0.2 = 0.1962 ##
Then we can sub this into the expression for ##\Delta x## as
\Delta x = \frac{\frac{1}{2} (0.1)(294.114)^2}{0.1962} \approx 22044.60882
So this is ##\approx 22## km
does that make sense?
thanks
OK
Then we have that
F_n = ma
So
a = \frac{F_n}{m}
seconds gives
\frac{
m
} = v_f
thanks
My apologies, I had put a mass of ##1kg## in my "quick" calculation. I was trying to be too clever.
You're still forgetting the distance it travels during the acceleration.
As an aside, let me show you a neat trick for these sorts of problems. You may or may not wish to remember this.
If an object accelerates from rest at a constant acceleration, then decelerates from this speed to rest at a constant deceleration. Then the average speed during both legs of the journey is the same: it's half the maximum speed.
You could solve this problem by working out the maximum speed, the time for each leg of the journey and the distance traveled would be half the maximum speed times the total journey time.
Likes gelfand
Hrm ok - i'll think about how to apply that to this (i'm not sure on first read)
is the rest of the problem sound now though?
thanks
thanks
The working is correct, but you definitely need units. You'll lose marks for that in an exam.
Likes gelfand
OK cool - thanks for the help
Related to How long an object takes to stop - using friction, momentum
1. How does friction affect the time it takes for an object to stop?
Friction is a force that opposes motion, so the more friction an object has, the longer it will take for the object to stop. This is because friction acts in the opposite direction of an object's motion, slowing it down.
2. Is the time it takes for an object to stop affected by its momentum?
Yes, the momentum of an object plays a role in how long it takes for it to stop. An object with a greater momentum will take longer to stop compared to an object with a lower momentum.
3. How can the coefficient of friction affect the stopping time of an object?
The coefficient of friction is a measure of the amount of friction between two surfaces. A higher coefficient of friction means there is more resistance to motion, so an object will take longer to stop. On the other hand, a lower coefficient of friction will result in less resistance and a shorter stopping time.
4. Does the surface of the object or the surface it is moving on impact the stopping time?
Yes, the surface of both the object and the surface it is moving on can affect the stopping time. Rough surfaces will have more friction, resulting in a longer stopping time, while smooth surfaces will have less friction and a shorter stopping time.
5. Can the shape of an object impact the time it takes to stop?
The shape of an object can also influence the stopping time. Objects with a larger surface area will have more friction and take longer to stop compared to objects with a smaller surface area. Additionally, the shape of an object can impact its aerodynamic properties, which can affect its overall momentum and thus the stopping time.
