How long does it take a 1ms pulse of light to travel 20m
In summary: This video shows the sort of fountain I was referring to - sometimes the stream is continuous, but I am referring to the one where it is turned on then off in a millisecond.The light stream in this video is traveling at 3 meters per second.If it's homework they mean you to look up the speed of light.
KezPhysics
If you create a 1 ms light pulse by turning a flashlight on and off, how long will the pulse take to reach the other side of the room 20m away? (in air at standard T and P) what is the length, in m, of the pulse?
I realize that light has a wavelength and when you pulse it that wavelength shouldn't change. Really I just don't know the right equations to solve the problem
I'm struggling with this pre-lab homework as I'm taking a physics paper out of interest and cannot find any concise or simple enough explanations of the answer in the readings I've been given or on the internet. Any help would be greatly appreciated.
Cheers
Do you know what light speed is? Do you know what "1 ms" is? Do you know what a "rate equation" is?
Likes phinds and berkeman
Welcome to the PF.
Cheers
If you throw a javelin that is 2m long at 20m/s horizontally where there is no gravity (so it keeps flying straight horizontally), how long does it take for it to reach 20m downrange? How long does it take it to pass through from tip-to-end the 100m mark?
ms is millisecond? not meters per second. so the period of the pulse, or the time that the light source was turned on then off again is 1ms, that is my understanding @berkeman if it were a pulse traveling at 1 m/s it would take 20s to cross 20m. but from my understanding the pulse's velocity is not given.
Is this homework or an exam question? If homework look up the velocity.
Homework, do you mean search on the forums for velocity?
You could Google for "what is the speed of light"
If it's an exam question they either give it to you or you are meant to know what I is.
CWatters said:
+1
I realize that this is a light problem. but I don't see how I would use the speed of light? with what formula?
What is the equation that relates distance, speed and time? Be sure to use units to help you get the equation correct.
Likes CWatters and Bystander
There are many modern water features/fountains/displays that have a stream of water turned on, then off a short time late (longer than a millisecond. The water streams I have seen seem to be traveling at about 3 m/s.
Suppose such a stream of water could move horizontally across a 6, room without falling to the floor. Let's say the speed of the water is 3 m/s, and the water was turned on for 0.1 seconds (one tenth of a second)
How long would the cylinder of water be (its diameter would be determined by the opening through which it passed when created), and how long would the cylinder of water take to cross the room?
Your light problem is very similar to this, it is just the light travels much faster.
This video shows the sort of fountain I was referring to - sometimes the stream is continuous, but I am referring to the pulses.
I think I figured it out. Handed it in yesterday. Used the equation for velocity, d/t. I was over complicating it a bit I think. Thanks a bunch for your help!
Related to How long does it take a 1ms pulse of light to travel 20m
1. How is the speed of light calculated?
The speed of light is calculated by dividing the distance traveled by the time it takes to travel that distance. In a vacuum, the speed of light is approximately 299,792,458 meters per second (m/s).
2. Why is the speed of light considered a constant?
The speed of light is considered a constant because it does not vary with respect to the observer's frame of reference. This means that no matter how fast an observer is moving or in which direction, the speed of light will always be the same.
3. How does the speed of light compare to other forms of energy?
The speed of light is the fastest known speed in the universe. It is approximately 670 million miles per hour (1.08 billion kilometers per hour). This is much faster than the speed of sound, which is only about 767 miles per hour (1,234 kilometers per hour).
4. How long does it take for light to travel a certain distance?
The time it takes for light to travel a certain distance depends on the medium through which it is traveling. In a vacuum, light travels at a speed of approximately 299,792,458 meters per second. So, for a distance of 20 meters, it would take approximately 0.000000067 seconds (or 0.067 microseconds) for a 1ms pulse of light to travel that distance.
5. Can the speed of light be exceeded?
According to the theory of relativity, it is impossible for any object with mass to reach or exceed the speed of light. However, some scientists are currently exploring the concept of faster-than-light travel through theoretical concepts such as wormholes and warp drives.
  • Other Physics Topics
