How Long Does It Take for a Mass to Oscillate Between Two Points on a Spring?
A vertical spring stretches 9.6 cm with a 1.3 kg block, which is then displaced an additional 5.0 cm and released. The problem involves calculating the time for the mass to oscillate between two points, 0.025 m above and below the equilibrium position. The correct angular frequency is determined to be 10.1, leading to the equations X1 and X2 for the oscillation. The initial calculations led to confusion regarding the use of radians versus degrees, which affected the time values. Ultimately, the correct times are t1 = 0.1 seconds and t2 = 0.2 seconds, confirming a total time change of 0.1 seconds.
shasanni
A vertical spring stretches 9.6 cm when a 1.3kg block is hung from its end.This block is then displaced an additional 5.0 cm downward and released from rest. Calculate the time it takes the object to go from a point 0.025 m below its equilibrium position to a point 0.025 m above it.
X1= Acos(Wt1)
X2=Acos(Wt2)
A represents the amplitude, which is 0.05 m. The W represents the angular frequency, which is 10.1
This is how I sent things up:
0.025=0.05cos(10.1t1)
-0.025=0.05cos(10.1t2)
and then I would have subtracted the two times, but I am not getting the correct values for t1 and t2. What am I doing wrong??
Btw, the answer is supposed to be 0.1s. T2 is 0.2s and T1 is 0.1s. ?
What did you get for t1 and t2?
ehild
This are the values I get:
t1= 0.507
t2=-.0507
cos(ωt1)=0.5 corresponds to ωt1=π/3.
cos(ωt2)=-0.5 corresponds to ωt2=π-π/3.
What are t1 and t2 then?
ehild
i think I know what the issue is. I have been using radians, not degrees!
t1 should 0.1 seconds and t2 should be 0.2 s. The change in time should be 0.1 seconds, which is the answer.
Well done! take care of radians and degrees in the future.
ehild
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up will act downwards and maximum static friction will act downwards Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
