How long does it take mass m to fall distance h?
  • Thread starter Thread starter vandersmissen
    Fall Mass
The discussion focuses on deriving the time it takes for a mass m to fall a distance h under the influence of gravity and friction. The participant sets up force equations involving tension, gravitational force, and friction, ultimately solving for acceleration. They express time t in terms of the variables m, M, h, θ, and the coefficient of friction μ, while clarifying the relationship between the normal force and gravitational force. The final formula for time is presented as t = {[(2h)(M+m)]/[g(m-Msinθ)-μMgcosθ]}^1/2, ensuring it aligns with the required variables. The conversation emphasizes the importance of correctly incorporating friction and normal force into the equations.
vandersmissen
[PLAIN]http://rawrspace.com/Capture.JPG
So when you draw out a force diagram, we find these two equations
mg-T=ma
rewriting in terms of T
T=mg-ma
and
T-MgSin\vartheta-f=Ma
T=Ma+MgSin\vartheta+f
I set the two equations equal to each other so I could solve for the acceleration since it is as rest when it starts (I figured that means that initial velocity is 0 )
setting them equal I get:
mg-ma=Ma+MgSin\vartheta+f
Then I moved them so that I could start factoring out terms:
g(m-MSin\vartheta)-f=a(M+m)
finally, solving for a:
[g(m-MSin\vartheta)-f]/(M+m)=a
I also know that y-y_0=V_0t-(1/2)at^2
Since y final is 0 and y_0 is h, I get this equation:
-h=-(1/2)at^2
So this means that
(2h/a)^(1/2)=t
Pluging in a that I solved for above, I get
{(2h)/[g(m-MSin\vartheta)-f]/(M+m)}^(1/2)=t
That was my answer of the time it takes for the mass m to fall a distance h. Does that seem correct to you, or am I overlooking something ?
It looks right to me except your answer has f in it and you are specifically required to write the answer in terms of m, M, h, θ and μ. So how can you get rid of f and introduce μ?
Thank you for taking a look. I don't know why I wrote it like that on here, on my paper I have μN for the frictional force instead of just the f for frictional force..
Thank's again for taking a look.
You're still not there because μN won't do either. What is N in terms of the given quantities m, M, h, θ?
Well N is the normal force so it is the opposite component the gravitational force which is Mg so it would be -Mgcos\vartheta wouldn't it (assuming I take my g to be positive)? That would still leave me with a g though which isn't in those terms. Is it okay to have g since it is a constant ? If so then I would replace -f with μMgcos\vartheta (it would be positive correct, as -f = -μN = -μ(-Mgcos\vartheta) )
So I would like to write my answer as
{(2h)/[g(m-Msin\vartheta)+μMgcos\vartheta]/(M+m)}^(1/2)=t
Don't forget that, in your original expression, f stands for the magnitude of the frictional force. That is a positive number. So f = μN = Mgcosθ. You already took care of the direction when you wrote down T-Mgsinθ-f=Ma.
So It would be μMgcosθ correct since N = Mgcosθ , and f = μN
So that means that it would be -μMgcosθ in the problem instead of -f
t={[(2h)(M+m)]/[g(m-Msinθ)-μMgcosθ]}^1/2
I believe that would be correct as it is now in the correct terms, I moved the M+m to the numerator. Does that seem correct now, If it was -f which took care of the magnitude since it subtracted in the original force equation. Then replacing it with the information I derived above should be correct.
Right.
Thank you for helping me understand where I went wrong.
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 22 ·
