How Long Does It Take to Heat an Object to 100 Degrees C by Convection?
In summary: Your Name] In summary, to determine the time it takes to heat an object of given length, 1cm, from both sides by convection, we can use the heat conduction and convection equations. The material's density plays a role in the convection equation, while the thermal conductivity and surface area are needed for the conduction equation. To determine the temperature at the surface of the material at this time, we can use the heat convection equation again, and solve for T2 using the power, convection coefficient, and initial temperature.
spacedout88
Want to heat an object of given length, 1cm, from both sides by convection. It is at a uniform temperature (5 degrees C) and is to be heated in an oven (200 degrees C) from both sides until its center reaches 100 degrees C. (the density of the material, its convection coefficient, and its conductivity coefficient are all given).
(a) Determine the time this takes.
(b) Determine the temperature at the surface of the material at this time.
2. The attempt at a solution
Heat conduction: P = (k*(T2-T1)*A)/t where k is the thermal conductivity.
Heat convection: P = h* (T2-T1)*A where h is the convection coefficient.
I'm not seeing the relation between convection and conduction in order to relate the two equations to each other. I'm also not sure where the material's density comes into play.
I'd appreciate any help, thanks!
Thank you for your question. In order to determine the time it takes to heat the object, we can use the heat conduction equation you mentioned: P = (k*(T2-T1)*A)/t. In this case, we are interested in the time it takes for the center of the object to reach 100 degrees C, so we can rearrange the equation to solve for t: t = (k*(T2-T1)*A)/P. We know the value of k, the thermal conductivity, and A, the surface area of the object, so we just need to determine the power, P, needed to heat the object from both sides.
To calculate the power, we can use the heat convection equation: P = h* (T2-T1)*A. Here, h is the convection coefficient, which takes into account the properties of the material, such as its density. So, the material's density does come into play in this equation. We also know the temperatures of the object's surfaces (5 degrees C and 200 degrees C), so we can plug in these values to calculate the power.
Once we have the power, we can plug it into the first equation to solve for the time it takes for the object's center to reach 100 degrees C.
To determine the temperature at the surface of the material at this time, we can use the heat convection equation again. This time, we are interested in the temperature at the surface, so we can rearrange the equation to solve for T2: T2 = (P/h) + T1. We already know the value of P and T1, so we just need to determine the value of h, the convection coefficient, to calculate the temperature at the surface.
I hope this helps clarify the relationship between convection and conduction in this problem. Let me know if you have any further questions. Good luck with your calculations!
FAQ: How Long Does It Take to Heat an Object to 100 Degrees C by Convection?
How does heating via convection work?
Heating via convection is a process where heat is transferred through the movement of a fluid, such as air or water. When a fluid is heated, it becomes less dense and rises, while the cooler, denser fluid sinks. This creates a cycle of movement that distributes heat throughout the space.
What types of heating systems use convection?
Convection heating can be found in various types of systems, including radiators, baseboard heaters, and forced air furnaces. These systems use either air or water as the fluid to distribute heat throughout a space.
What are the benefits of heating via convection?
One of the main benefits of convection heating is that it provides consistent and even heat distribution throughout a space. It also tends to be more energy-efficient than other heating methods, as it does not require a lot of electricity or fuel to operate.
Are there any downsides to heating via convection?
One potential downside to convection heating is that it can take longer to heat up a room compared to other methods, such as radiant heating. This is because the air or water needs to reach a certain temperature before it can effectively distribute heat. Additionally, convection heating may not be suitable for spaces with high ceilings, as the heated air or water may rise and accumulate near the ceiling rather than evenly distributing throughout the room.
Can convection heating be used for cooling as well?
Yes, convection heating can also be used for cooling by reversing the direction of the fluid flow. In this case, the cool air or water would be pushed into the space, while the warm air or water would be pulled out. This method is commonly used in air conditioning systems and can also be found in some types of radiant cooling systems.
