B How long it takes the Earth to fall halfway to the Sun--ellipse method
The discussion centers on calculating the time it takes for Earth, initially at 1 AU from the Sun and suddenly stopped, to fall halfway to the Sun. A clever approach involves using Kepler's laws, particularly focusing on the concept of degenerate ellipses and the extreme eccentricity of the orbit when the Earth has no tangential speed. While determining the time to fall the entire distance to the Sun is more straightforward, estimating the time to fall halfway can be approximated by analyzing the area swept out in an elliptical orbit with high eccentricity. The time to reach the halfway point is suggested to be very close to the total fall time, as the majority of the area is covered in the first half of the fall. This method emphasizes the relationship between area and time in orbital mechanics.
bruhh
TL;DR Summary
How long does it take for the Earth to fall half the distance to the Sun, without calculus?
There's a classic physics problem that is:
If Earth is orbiting the Sun at 1 au from and is suddenly stopped. How long does it take to fall into the Sun (neglecting the size of the Sun/Earth)?
I know that a clever way to solve this problem is by using degenerate ellipses and an object "falling" into the Sun is the equivalent of the object orbiting the Sun with very high eccentricity. Halving the semi-major axis of the orbit and using Kepler's Law gives: T=1AU/(4√2). However, I want to apply to strategy to another similar problem. This time:
If Earth is orbiting the Sun at 1 au from and is suddenly stopped. How long does it take for the Earth to travel half the distance to the Sun(neglecting the size of the Sun/Earth)?
If we were to use the result for T from the first problem and then simply apply Kepler's 2nd Law by looking at ratios of areas, we should be able to find this new time it takes to fall halfway to the Sun. However, I am having a problem visualizing what area of the ellipse the Earth covers when it travels half the distance to the Sun. I know about the calculus solution which is really bashy, so I would like some assistance with figuring out this more elegant method.
Use Kepler's third law to find the period of an elliptical orbit where the semi-major axis is the half the radius of the Earth's current orbit.
When stopped, the Earth is at the farthest point from the sun. Since the Earth would have no tangential speed, the orbit is the extreme elliptical orbit where the semi-minor axis is 0. In other words, and eccentricity of the ellipse is 1, putting the focii at the extrema of the ellipse. So the other extrema (also the other focus) is the centre of the sun (for practical purposes).
AM
As you will no doubt have realized, it is much easier to determine the time to fall to the sun rather than the time to fall halfway to the sun. But you can ball-park it by taking an ellipse with an eccentricity close to 1, which represents the orbit of the Earth with very little angular momentum relative to the centre of the sun. The area swept out by the Earth in the time it takes to reach the half way point is most of the area of one half of the ellipse. The remaining area of that half ellipse is a tiny fraction of the area swept out in the first half of the fall. Since the orbiting body sweeps out equal areas in equal times, you can see that it takes a small fraction of that time to fall the rest of the way. This means that the time it takes to fall half way is very close to the time it takes to fall the entire way.
You can verify this by figuring out the speed of the Earth at the half-way point using change in potential energy = - change in kinetic energy.
AM
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
