How long to turn off fluorescent lights?
  • Thread starter Loren Booda
  • Tags
    Lights
In summary, turning off fluorescent lights saves energy. It takes seconds for the lights to break even with the starting current.
Loren Booda
3,125
How long at least must I turn off my fluorescent lights to save energy?
Science news on Phys.org
Forever would be best...
I suppose you mean how long would they have to be off to cancel out the effect of the starting current. Most modern fuorescents use electronic ballasts, which are fast starting and use very little extra power. So mere seconds is all it takes.
There was a chart for this but I can't find it.
It was only worth leaving them on for the oldest technology fluorescent tubes ( the ones that flicker when you start them), which took something like 20seconds to break-even.
Yeah, the inrush current to load the ballasts was much larger than the current required to maintain the arc, once established. If anybody here has balky fluorescents in their garage/attic/cellar that don't have diffusers, when you turn them on and they just glow faintly and sputter, you should quickly swipe your hand along the surface of the tube to create a static potential, and the light will usually come on, nice and bright. When my wife and I were considering renting an early 19th century brick house (cold,cold,cold) from my boss back 30 years ago, he was showing me through some closed-off rooms in the upstairs and one room had this type of lighting. It failed to do more than glow dimly and pulse, so I swiped the tubes to light them, and he said "I've got to spend more time with you. What else do you know?"
A Mythbusters segment looked at this a while ago. I think their conclusion was that if you were going to be out of the room for more than a few seconds, turn the lights off.
Looks like we have a good answer to the question, so it must be time for a story.
I used to work in an interior (no windows) storage room, it was a long narrow room with exits to a hall way at each end. My desk sat near one of the exits. One day a professor was bringing in students for a brief conference through the exit at the far end of the room. As he left, he very consciencously turned out the lights. This left me sitting in the dark. I had to fumble my way over to a light switch, to turn the lights back on. A few minutes later, the same prof came in with another student. I sort of figured that he would see the lights on and figure out that he should leave them on. Nope, he shut them off again. After about the 3rd time I managed to get his attention to let him know he should leave the lights on.
The moral of the story.. be sure the room is empty before you turn our the lights to save a few pennies worth of electricity.
Question: Any suggestions on how to keep track of the number of hours the flourescent ceiling lights are left on in my daughter's dorm room? The lights are controlled by a wall switch. It's for a green project they're doing. We don't need to control the usage.
Thanks!
Easiest way (without making any electrical connection to the wiring) is probably to have a web cam take a picture every 10mins and a bit of simple software to measure the brightness of the image.
Hmm, that's a pretty good idea and if they only need a few days worth of data, they could sort it manually too.
FAQ: How long to turn off fluorescent lights?
How long should I wait before turning off fluorescent lights?
The general rule for turning off fluorescent lights is to wait at least 15 minutes before turning them back on again. This allows the bulbs to cool down and prevents them from burning out prematurely.
Does turning off fluorescent lights save energy?
Yes, turning off fluorescent lights when they are not in use can save a significant amount of energy. Fluorescent lights use a small amount of energy when they are first turned on, so turning them off when not in use can help reduce energy consumption.
Will turning off fluorescent lights frequently reduce their lifespan?
Fluorescent lights have a limited number of on/off cycles before their lifespan is affected. However, the impact is minimal and turning off fluorescent lights when not in use is still recommended to save energy. It is important to note that leaving fluorescent lights on for extended periods of time can also shorten their lifespan.
Can turning off fluorescent lights too often cause flickering?
In most cases, turning off fluorescent lights frequently should not cause flickering. However, if the bulbs are old or faulty, they may flicker when turned on. This is a sign that the bulbs need to be replaced.
How long do fluorescent lights last when turned off?
Fluorescent lights generally have a long lifespan, even when turned off frequently. The average lifespan of a fluorescent bulb is around 10,000 hours, which is equivalent to over a year of continuous use. Turning off fluorescent lights when not in use can help prolong their lifespan.
