How long will it take an electromagnetic wave to reach a satellite
In summary, GPS uses electromagnetic waves to determine the distance between a satellite and an individual. If a satellite is located at a distance of 127.2km and is moving away at a speed of 12.0km/s, it would take approximately 10.6 seconds for an electromagnetic wave to reach the individual. The frequency difference between the emitted frequency of 10.0 GHz and the observed frequency can be calculated using the formula fo=fs(1+/-vrel/c) if vrel<<c. However, it is important to note that this formula is based on the theory of relativity and a more accurate calculation may be necessary for future problems involving speeds closer to the speed of light.
aChordate
76
GPS determines your distance from a satellite by measuring how long it takes an electromagnetic wave to travel from the satellite to you. Imagine that a satellite is located at a distance of 127.2km and is moving away from you at a speed of 12.0km/s.
a)how long will it take an electromagnetic wave emitted by the satellite to reach you?
b)if the frequency of the wave emitted by the satellite is precisely 10.0 GHz, what is the frequency difference between this frequency and the frequency that you observe?
d=127.2km=127.2*103m
v=12km/s=12*103m/s
fs= 10GHz= 10*10^9Hz
c=3.00*108m/s
Part A: 10.6 seconds
Part B:
f0=10*109 Hz (1-(12*103m/s/3.00*108m/s))=10*109 Hz
v=12km/s=12*103m/s
c=3.00*108m/s
Part B:
For Part A, don't you think the time will have rather more to do with the speed of light than the speed of the satellite? For Part B, don't you think keeping more accuracy in the answer might be useful?
In addition to the problems pointed out in post #2 you have the wrong formula for the Doppler shift.
It's based on the theory of relativity so don't try to derive it. Look it up.
Depends on how much accuracy you need. It certainly doesn't matter if you round to the nearest GHz, like aChordate. But if I use the nonrelativistic formula and compare the results with the relativistic the frequency shifts are the same to 4 decimal places.
I doubt that the OP was aware of that. In any case, he/she might as well use the correct formula in case a future problem involves speeds closer to c.
EDIT: I have to admit that, if the emphasis was on satellites, the OP might never encounter the relativisic formula, so on second thoughts I think you were right to point out what you did.
Related to How long will it take an electromagnetic wave to reach a satellite
1. How is the speed of an electromagnetic wave calculated?
The speed of an electromagnetic wave is calculated using the equation c = fλ, where c is the speed of light (which is approximately 3 x 10^8 meters per second), f is the frequency of the wave, and λ is the wavelength of the wave.
2. How long does it take an electromagnetic wave to reach a satellite?
The time it takes for an electromagnetic wave to reach a satellite depends on the distance between the satellite and the source of the wave, as well as the speed of the wave. On average, it takes around 0.25 seconds for an electromagnetic wave to travel from Earth to a satellite in geosynchronous orbit, which is approximately 36,000 kilometers away.
3. How does the distance between a satellite and Earth affect the time it takes for an electromagnetic wave to reach it?
The distance between a satellite and Earth is directly proportional to the time it takes for an electromagnetic wave to reach it. This means that the farther the satellite is from Earth, the longer it will take for the wave to reach it. This is because the speed of light is constant, so the longer the distance, the more time it takes for the wave to travel.
4. Can the speed of an electromagnetic wave be affected by external factors?
No, the speed of an electromagnetic wave is constant and cannot be affected by external factors. However, the wavelength and frequency of the wave can be altered by certain materials or mediums, which can affect how the wave travels.
5. Are there any other factors that can affect the time it takes for an electromagnetic wave to reach a satellite?
Aside from the distance between the satellite and Earth, the speed of the wave and any potential interference from materials or mediums, there are no other significant factors that can affect the time it takes for an electromagnetic wave to reach a satellite. However, certain atmospheric conditions, such as weather, can cause slight delays or interference in the transmission of the wave.
9K
12K
