How Long Will it Take Me to Catch The Bus?
  • Thread starter bleedblue1234
  • Tags
    Bus
In summary, Lisa is running at a constant speed of 5.05 m/s while the bus is pulling away with a constant acceleration of 1.10 m/s/s. The question is when and where will Lisa catch the bus using the bus's initial position as the reference point. To solve this, we can set up equations using the formula DeltaX= Vot+1/2a(t)sqrd and solve for t to find when Lisa will catch the bus, and then use this value to find where she will catch it.
bleedblue1234
109
Lisa is late for the school bus! (Oh - no) As Otto is pulling away with a constant acceleration of 1.10 m/s/s. Lisa is 11m away and running at a constant speed of 5.05 m/s..
When will Lisa catch the bus?
Where will Lisa catch the bus using the bus's initial position as the referance point?
Honestly I have sat here thinking for about 30 minutes... any insight on how to start would be great... (I don't just want the answer)
Hi bleedblue1234
I think the initial speed of the bus is zero. If I interpret the question correctly, it will be like this :
Assume that Lisa catches the bus at point X after both of them move for t seconds. At that time, the bus will travel distance d and Lisa will travel distance 11 + d.
Now set up two equations and solve for t and use the value of t to find where Lisa will catch the bus. :smile:
I would approach this problem by first defining the variables and using the given information to set up a mathematical equation. In this case, the variables would be time (t), distance (x), initial velocity (Vo), and acceleration (a).
Using the formula DeltaX= Vot+1/2a(t)sqrd, we can plug in the given information to solve for the time it will take Lisa to catch the bus.
First, let's define the initial position of the bus as the reference point, meaning that x=0 at t=0. In this case, Lisa's initial position (xo) would be 11m away from the bus. So our equation becomes:
0=5.05t+1/2(1.10)(t^2)+11
Next, we can simplify this equation by multiplying 1/2(1.10)(t^2) to get:
0=0.55t^2+5.05t+11
Now we can use the quadratic formula to solve for t, which will give us the time it takes for Lisa to catch the bus:
t= (-5.05±√(5.05^2-4(0.55)(11)))/2(0.55)
Solving this equation, we get two possible times: t=1.50s or t=-4.55s. Since time cannot be negative, we can discard the negative solution and conclude that it will take Lisa approximately 1.50 seconds to catch the bus.
To determine where Lisa will catch the bus, we can plug this time back into our original equation to solve for the distance (x):
x=5.05(1.50)+1/2(1.10)(1.50^2)+11
Solving this equation, we get x=19.02m. This means that Lisa will catch the bus 19.02m away from its initial position.
I would also consider other factors that may affect this scenario, such as the precision of the given values and whether the bus is moving in a straight line or on a curved path. I would also suggest that Lisa try to run faster to catch the bus sooner!
Related to How Long Will it Take Me to Catch The Bus?
1. How long does it typically take to catch the bus?
The time it takes to catch the bus depends on several factors, such as the distance from your location to the bus stop, traffic conditions, and the bus schedule. On average, it takes around 5-10 minutes to catch the bus.
2. Does the time of day affect how long it takes to catch the bus?
Yes, the time of day can affect how long it takes to catch the bus. During peak hours, there may be more traffic and the bus may take longer to arrive at the bus stop. On the other hand, during off-peak hours, the bus may arrive at the bus stop faster.
3. How can I find out the exact time the bus will arrive at my stop?
You can find out the exact time the bus will arrive at your stop by using a bus tracking app or checking the bus schedule online. These resources provide real-time updates on the bus's location and estimated arrival time at your stop.
4. Is there anything I can do to make sure I catch the bus on time?
Yes, there are a few things you can do to ensure you catch the bus on time. Arrive at the bus stop a few minutes early, check the bus schedule or tracking app before leaving, and have your bus fare or pass ready to avoid any delays.
5. What should I do if I miss the bus?
If you miss the bus, you can either wait for the next bus or consider alternative transportation options. You can also try to catch the bus at the next stop if it's within walking distance. It's essential to plan ahead and give yourself enough time to catch the bus to avoid missing it.
11K
